I have build a recording light for my Studio and the blink example works fine. i copied a code from this forum and i guess it will work if i only could install the 'arduino_midi.hex' to it.
when i klick on 'add zip library' i can't select the file... i even tried this on my friends windows 10 laptop with xloader; seemed to be ok, but i even can't find the board on my midi setup (Cubase/Logic/ProTools/AudioMidiSetup)..
is there another way to install hiduino to my board? Remember: using macbook pro from 2021 (M1 Chip)
i've read almost every thing on the Internet about it, but i didn't get it done.
When you scroll down, you will see the instructions.
"add zip library" is a funktion of Arduino IDE to make libraries available to install... but i can't import the library to IDE, cause they are shown as gray (unklickable) files..
Do you know how to install via ISP or dfu-programmer?
Sooo.... Problem was solved by learning the new commands for Terminal like: "cd Downloads/..." instead of "cd/users/'username'/Downloads/........"
i have now installed it via homebrew in the terminal.. but the "add ZIP. Library" funktion in Arduino IDE isn't working at all... don't know what the problem is with this...
