Can't upload my program to Arduino mega ADK
I am constructing a robot with an Arduino mega ADK on it. Now I wrote a little example to try if everything on it works, but I'm not even able to upload my program on the Arduino. I've received this error message:
Arduino: 1.8.1 (Windows 10), Board: "Arduino Mega ADK"
Sketch uses 1004 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": Das System kann die angegebene Datei nicht finden.
avrdude: ser_drain(): read error: Das Handle ist ungültig.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: Das Handle ist ungültig.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Invalid library found in C:\Users\Wellenberg\Documents\Arduino\libraries\Serial_RF_Pro_Demo_Code: C:\Users\Wellenberg\Documents\Arduino\libraries\Serial_RF_Pro_Demo_Code
option enabled in File -> Preferences.
Is there sb who can help me?
Thank you very much!
Wellenberg
http://forum.arduino.cc/index.php?topic=52113.0
Thanks for your help! That doesn't help.
I tried before.
I tried updating the driver using this software, but I failed.
Is there another possibility how I can fix my problem?
Just a generic possibility that you may have already tried - are you sure the device is on COM3? The way I test is to remove the Arduino, then open up the port selection menu. Note any ports that show. Now connect the Arduino and repeat. The Arduino is connected to any new port that appears.
I tried to check the COM Ports, but I don't even have the possibility to open the Ports segment under Tools.
Connecting the Arduino Mega ADK doesn't change sth.
I receive all the time this error message:
Invalid library found in C:\Users\Wellenberg\Documents\Arduino\libraries\Serial_RF_Pro_Demo_Code: C:\Users\Lukas\Documents\Arduino\libraries\Serial_RF_Pro_Demo_Code
I deleted the library posing problems.
Now I received another error message:
Sketch uses 1292 bytes (0%) of program storage space. Maximum is 253952 bytes.
the selected serial port avrdude: stk500_send(): failed to send command to serial port
 does not exist or your board is not connected
But the builtinLed on pin 13 on the Arduino Mega ADK give light, and the USB b cable is the only connection.
I only have a seeedstudio-Grove shield for the Arduino Mega ADK and the USB B cable connected to the Arduino Mega ADK.
