Blink is happily Blinking along... but when I swtich again to the new sketch, I get tons of SerLCD-related errors, the Title area of the bottom window is 'Error building library "LCD"'.
Then, here is the beginning of the errors (note that I am not doing anything with LCDs in this, but did in the earlier sketch). This goes on and on and on...
serlcd-v2.c:75:73: error: d:\Pics\c\16F688.h: Permission denied
serlcd-v2.c:76:32: error: d:\Pics\c\int16CXX.H: Permission denied
serlcd-v2.c:78: warning: ignoring #pragma config
serlcd-v2.c:134: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'letter'
serlcd-v2.c:135: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cursor_position'
serlcd-v2.c:136: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'splash_enable'
serlcd-v2.c:138: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'backlight_counter'
serlcd-v2.c:139: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'brightness_setting'
serlcd-v2.c:140: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Backlight_Setting'
serlcd-v2.c:142: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'LCD_Type'
And here's the sketch I'm trying to upload:
#include <OneWire.h>
OneWire ds(10); // on pin 10
void setup(void) {
// initialize inputs/outputs
// start serial port
void loop(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
if ( !ds.search(addr)) {
Serial.print("No more addresses.\n");
ds.reset_search();
return;
Serial.print("R=");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
Serial.print(" ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
if ( addr[0] != 0x10) {
Serial.print("Device is not a DS18S20 family device.\n");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print("P=");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print( OneWire::crc8( data, 8), HEX);
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print("\n");
