Can't upload prog from Mac intl PB
When I try to upload a program from Arduino I get the following message in red in the serial window area below the program area:
java.lang.NullPointerException
at processing.app.Serial.setDTR(Serial.java:480)
at processing.app.Uploader.flushSerialBuffer(Uploader.java:76)
at processing.app.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:69)
at processing.app.Sketch.upload(Sketch.java:1699)
at processing.app.Sketch.exportApplet(Sketch.java:1761)
at processing.app.Editor$42.run(Editor.java:1955)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Any idea what is wrong? The port works with a mouse. The board was working yesterday on a different (PPC) powerBook. I’m trying to upload the “blink” program.
Thanks,
ergoman
Thats a fancy way of saying “I cant find the Serial port.” :slight_smile:
Double check that you’ve selected the correct one and that all the cables are connected properly.
Thanks! That was the problem. I needed to select the correct serial port in the tools/serial port menu.
Wouldn’t it be nice if the program error message were as clear and succinct as your message!
Ergoman
