Can't upload program to Arduino Leonardo from Mac
I'm new to programming Arduino boards. I have an Arduino Leonardo with Headers and I'm trying to upload a program to it. I've been getting this error:
avrdude: error: programmer did not respond to command: exit bootloader
Here's my Build Options:
Board: "Arduino Leonardo"
Port: "dev/cu.Bluetooth-Incoming-Port"
Programmer: "AVRISP mkll"
I'm assuming my Port or Programmer isn't configured correctly. What should the Port and Programmer be? Do I need to install a driver?
(It also might be that I'm using a charge only micro usb cable.)
Fix that first.
AWOL:
Fix that first.
Well, assuming that I have the correct cable, is there anything about my current setup that's wrong?
I have no idea about Macs
But it's extremely impolite to modify a post after it has been responded to.
adamzarn:
The Tools > Programmer selection only matters during the Tools > Burn Bootloader and Sketch > Upload Using Programmer operations. If you're doing a standard Upload then it makes absolutely no difference what you have selected in that menu.
adamzarn:
That's definitely not the right port. Select the port of your Leonardo from the Tools > Port menu.
