I just tried uploading a new sketch to my Arduino, and I got the errors:
Binary sketch size: 5138 bytes (of a 14336 byte maximum)
hardware/tools/avrdude -Chardware/tools/avrdude.conf -v -v -v -v -pm168 -cstk500v1 -P/dev/ttyS0 -b19200 -D -Uflash:w:/home/alex/arduino/morse_code/applet/morse_code.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 22 2007 at 13:15:12
System wide configuration file is "hardware/tools/avrdude.conf"
User configuration file is "/home/alex/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyS0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: Send: Q [51] [20]
Neither the TX or RX LEDs light up, but the pin 13 LED does blink once (which indicates the bootloader staring, right?), and the power LED is on. It's not touching anything that could conduct electricity, and the proper port is selected in the IDE. There isn't anything plugged into it (other than the USB). It's a Diecimila, and I'm running Arch Linux. Right before this happened the Arduino was reading stuff from Serial.read(), then outputting stuff with Serial.println ().
Can anyone tell me what's up?
e: Also, when I first plug it in the TX and RX LEDs flicker for a moment. I'm trying it on another computer now, I'll let you know what happens.
e2: I just tried it on another computer running Windows XP and I got these errors:
Binary sketch size: 1096 bytes (of a 14336 byte maximum)
C:\arduino-0011\hardware/tools/avr/bin/avrdude -CC:\arduino-0011\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pm168 -cstk500v1 -P\\.\COM4 -b19200 -D -Uflash:w:C:\arduino-0011\examples\Digital\Blink\applet\Blink.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
System wide configuration file is "C:\arduino-0011\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM4
avrdude: ser_open(): setting dtr
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done. Thank you.
Thanks.
