Hello,
I've bought a bare bone arduino kit to use in my project from here. I've tried uploading a sketch, but i get this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc3
If i use an other one it works. I've tried the loop-back test and it succeded.
What can I do to make it work again?
bicknos:
Another one of what? Another entire kit? What is the faulty part?
an other chip, if I put a working chip in my circuit it works, if i put the chip i've got with the kit it doesn't work
Ok, since you have a working Arduino, you can upload the example ArduinoISP sketch to it, and use it as an ISP programmer, and burn the bootloader to the chip that is not working. The chip that is not working probably just doesn't have the bootloader on it.
i've tried this tutorial, but i've got this error message"
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Fout bij het branden van de bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
I'm 100% sure evrything is good connected
If you have neat wiring and can upload a photo that shows clearly how you have it wired, it may help. I think that device signature 0x000000 means the chip is not running the clock. You may try removing the capacitors and see what you get.
