Can't upload projects
I am using an Arduino Mega 2560 with Arduino IDE version 1.0.6, on a windows 8.1 computer 64-bit. Every time I try to upload a project, I get this:
“Show verbose output during compilation”
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: “Arduino Mega 2560 or Mega ADK”
Binary sketch size: 1,636 bytes (of a 258,048 byte maximum)
processing.app.SerialNotFoundException: Serial port ‘COM3’ not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.(Serial.java:191)
at processing.app.Serial.(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1666)
at processing.app.Sketch.exportApplet(Sketch.java:1622)
at processing.app.Sketch.exportApplet(Sketch.java:1594)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2382)
at java.lang.Thread.run(Thread.java:619)
I had it configured to COM3 and working before. Now it just doesn’t want to work. All helpful responses will be appreciated! :slight_smile:
Arduino boards have a tendency to change their ports when they are reconnected.
You can have a look in your Device Manager to see the port that it is assignes currently.
