Can't upload second sketch - could be com5 to com3 enumeration change
I got a tutorial to work but I can't upload a new sketch now. I have checked that the old sketch is still working and the USB serial port should be available to the Arduino IDE.
Perhaps a Win10 software update which apparently changed the COM enumeration from COM5 to COM3 is the culprit. Is there something in a file that I need to check/change? I'll update after trying some more things.
This is the tutorial I got to work first:
I'll try more things and look for script/text files to modify after rebooting my desktop.
See the attachment for verbose info. (Exceeded 9000 characters with paste.)
secondUploadErr.txt (30.8 KB)
This looks like it's in the main troubleshooting post. I'll find another USB port and see if it enumerates differently, etc.
I didn't see it there before I posted.
I moved the cable to a different USB port and it still enumerated as COM3.
I found the COM3 and COM4 ports apparently reverted to windows drivers after a Win10 update. I went to the board manager and updated the Intel Curie Boards by Intel v1.0.4 on top of itself.
I can upload sketches now.
If you go to Windows Device Manager and see USB Serial Port (COM3) it won't work (but a lot of serial communications still will). It now says "Arduino 101 Serial Monitor (COM3)" in Windows Device Manager.
I had it working and then saw core 1.0.5 was available. After installing it, I don't seem to have an arduino101load:
This command:
C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.4+1.18/arduino101load
From this command line:
C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.4+1.18/arduino101load/arduino101load C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.4+1.18/x86/bin C:\Users\fred\AppData\Local\Temp\build7378a3afc629c80c8622440c492bb46a.tmp/sketch_mar30a.ino.bin COM3 verbose
Is missing here:
Directory of C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.4+1.18
03/31/2016 01:56 PM .
03/31/2016 01:56 PM ..
0 File(s) 0 bytes
I got core 1.0.5 to install, and successfully ran the heart rate BLE sketch.
