Can't upload sketch on 168 Nano clone
Hello, I just got some Atmega 168 Nano boards from ebay from ying2022 (here is the linkhttps://www.ebay.com/itm/374692190260 ) and can't download any sketches on them. The CH340 driver is installed and is working properly and I have no problems downloading sketches on 328 clones ( for sanity check I tried 3).
When I try to upload any sketch from IDE examples I get a following messages:
Sketch uses 860 bytes (5%) of program storage space. Maximum is 14336 bytes.
Global variables use 15 bytes (1%) of dynamic memory, leaving 1009 bytes for local variables. Maximum is 1024 bytes.
type or paste code here
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x27
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
for other type of chip there are other types of options. what processor did you selected before uploading?
there is only one option for 168
зображення
maybe there is no bootloader?
if after powering on no LED flashes three times then no bootloader is burned. you can use other arduino as programmer "ArduinoAsISP"
