can't upload sketch to arduino yun over usb or wifi
i dont know what happens for my arduino yun, when i try to upload sketch over usb, there is error says cant find port!
when i plug in my arduino yun to my PC via usb, and from the IDE, i can choose the port, but when i upload the sketch, the arduino yun disconnect from my PC. and IDE shows error, so i close the IDE and open it again, the arduino yun connect to PC again and you can also find the port, but the port number changes.
but i can upload sketch via wifi sometimes, however after upload it successfully, i cant go to address like http://arduino.loacl/arduino/sketchname, it will show: Could not connect to YunServer 146 Connection refused, and another thing happen, i can go to address: http://arduino.local/sd/sketchname
so i think it maybe arduino part has problems, so, how to deal with it, anyone meet this?
also i find when i upload sketch via usb, besides it will disconnect from PC, it's l13 will be red and rx tx will flash
i find where the problem is, the bridge does not work!!! the sketch hangs on the
bridge.begin();
im still trying to find the way to solve it, and i find someone said:
alexafa:
Hello!
This is my solution.
Create a new file int ‘/etc/rc.d/’ named ‘K49stop-mcu’ (Scripts that run at shutdown)
#nano K49stop-mcu
Add this content:
#!/bin/sh
echo 18 > /sys/class/gpio/export
echo “high” > /sys/class/gpio/gpio18/direction
echo 1 > /sys/class/gpio/gpio18/value
echo 18 > /sys/class/gpio/unexport
Save, exit and change permissions:
chmod 7777 K49stop-mcu
It is done.
MCU stops before restarting and so the bridge does not fail booting Linino.
but i dont know how?
