Can't upload sketch to ESP8266 using Arduino IDE 2.1.0
Hey. I'm trying to upload this ChatGPT code (hope it's correct) to my ESP8266 NodeMCU v3 CH340 using Arduino IDE 2.1.0.
It's stuck on
"Leaving...
Hard resetting via RTS pin..."
Maybe that's because display pins are not soldered but connected via a breadboard to hold them in place.
Here's the code:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <Encoder.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
// Wi-Fi credentials
const char* ssid = "MyWiFi";
const char* password = "FUN0PASS4U";
// WebSDR URL
const char* websdrUrl = "http://websdr.ewi.utwente.nl:8901/";
// Display pin connections
#define TFT_CS   D8
#define TFT_RST  D3
#define TFT_DC   D4
#define TFT_SDA  D7
#define TFT_SCL  D5
#define TFT_BL   -1  // No pin assigned for backlight control
// Speaker pin connections
#define SPEAKER_POSITIVE D2
#define SPEAKER_GROUND   GND
// Encoder pin connections
#define ENCODER_CLK D1
#define ENCODER_DT  D0
#define ENCODER_SW  D8
// TFT display object
Adafruit_ST7735 display = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST, TFT_SDA, TFT_SCL);
// Encoder object
Encoder encoder(ENCODER_CLK, ENCODER_DT);
// Variables
int mode = 0;
int frequency = 4625;
  // Initialize Serial communication
  // Connect to Wi-Fi network
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("Wi-Fi connected");
  Serial.println("IP address: ");
  // Initialize the TFT display
  display.initR(INITR_BLACKTAB);
  display.setRotation(3);
  display.fillScreen(ST7735_BLACK);
  display.setTextSize(2);
  display.setTextColor(ST7735_WHITE);
  display.setCursor(0, 0);
  display.println("Mode: WebSDR");
  display.println("Frequency:");
  display.println(frequency);
  display.setRotation(0);  // Reset rotation
  display.begin();
  // Check if the encoder has been turned
  int16_t delta = encoder.read() * 10; // Increase sensitivity to 10 Hz per step
  if (delta != 0) {
    frequency += delta;
    // Limit the frequency range
    if (frequency < 0) {
      frequency = 0;
    if (frequency > 30000) {
      frequency = 30000;
    // Update the TFT display
    display.begin();
    // Delay to debounce the encoder
    delay(100);
  // Check if the encoder switch is pressed to toggle mode
  if (digitalRead(ENCODER_SW) == LOW) {
    toggleMode();
    // Delay to debounce the switch
    delay(200);
  // WebSDR mode
  if (mode == 0) {
    // Connect to the WebSDR server
    WiFiClient client;
    if (client.connect("websdr.ewi.utwente.nl", 8901)) {
      // Send HTTP GET request to the WebSDR server
      client.print("GET /?tune=0");
      client.print(frequency);
      client.print("z HTTP/1.1\r\n");
      client.print("Host: websdr.ewi.utwente.nl\r\n");
      client.print("Connection: close\r\n");
      client.print("\r\n");
      // Read and discard the HTTP response headers
      while (client.connected() && !client.available());
      while (client.available()) {
        client.read();
      // Read and print the WebSDR audio data
      while (client.connected() && client.available()) {
        // Read audio data and play it through the speaker
        byte audioData = client.read();
        analogWrite(SPEAKER_POSITIVE, audioData);
      // Connection failed
      Serial.println("Connection to WebSDR server failed");
void toggleMode() {
  mode = (mode + 1) % 2;
  if (mode == 0) {
    display.begin();
    display.println("Mode: Encoder");
    display.println("Adjust frequency");
    display.begin();
The sketch is created to listen to the WebSDR, change frequencies, and modes using the encoder, and show everything on the TFT display. And I don't know if ChatGPT used in the code how the pins are connected:
Speaker > NodeMCU
- Positive > D2
- Negative > G
Display > NodeMCU
- GND > G
- VCC > 3V
- SCL > SC
- SDA > D2
- RES > D3
- DC > D4
- CS > SK
- BLK > D8
Encoder > NodeMCU
- CLK > D6
- DT > D7
- SW > D0
- VCC > 3V
- GND > G
Forgot to mention that I'm new to Arduino or ESP8266. Like started today.
FYI:
That message actually means that the upload is almost done and successful.
Just see if you get a message pop up at the bottom right of the IDE window that say Upload done or something like that.
Can't recall the actual message.
Why not ask ChatGPT?
You will not believe it, but I asked. Nothing helped.
I waited for 20 mins with no progress at all.
Maybe someone has a better code and can share it, I would appreciate that.
Nobody has whatever code You want because You have not specified at all what it is supposed to do.
The idea of forum is to help members learn and grow in programming. Forum is not a code factory for free give away code.
So AI is sometimes better. It can provide help for free. The problem is fixed, thanks to ChatGPT.
