Sick of broken English and half assed instructions.
Zapier? Doesn't offer a "hook" option anywhere, and that's like the
VERY first thing in the IOT instructions. So right off the bat its broken.
Ok. Lets try something simple like plugging it in.
Oh, look! A driver installed! YAY!
Ok, lets search the IDE for MKR1000.
Nope, that requires some other thing.
OK, found the other thing, chose MKR1000 from the board list!
GREAT!
Now to upload a skeleton sketch.
WRONG! DENIED. BROKEN ![]()
Please do this:
- File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
- Sketch > Upload
- After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
- Paste the error messages in a reply here USING CODE TAGS (</> button on the forum toolbar).
Dear Sir,
I also fail to upload sketh to MKR1000, the error message is as follows:
Arduino: 1.8.12 (Windows 10), Board: "Arduino MKR1000"
Sketch uses 30280 bytes (11%) of program storage space. Maximum is 262144 bytes.
Global variables use 5828 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port COM14
PORTS {COM14, COM17, } / {COM14, COM17, } => {}
Uploading using selected port: COM14
C:\Users\Joe\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM14 -U true -i -e -w -v C:\Users\Joe\AppData\Local\Temp\arduino_build_892166/mkr1000_receive_mkr1_serial2_send_blue2.ino.bin -R
An error occurred while uploading the sketch
option enabled in File -> Preferences.
May I have your suggestions?
Many thanks.
- If you cannot select the port, please click "upload" anyway and once you see in the console a text like the following one, please give quick double tap to the reset button:
PORTS {COM131, } / {COM131, } => {}
- Ca you see the ports under device manager once you click the reset button twice
- Does the double tap show the fading behaviour of LED?
