Arduino: 1.8.7 (Windows 10), Board: "Sanguino 1284p, ATmega1284P (16 MHz)"
Sketch uses 4658 bytes (3%) of program storage space. Maximum is 130048 bytes.
Global variables use 482 bytes (2%) of dynamic memory, leaving 15902 bytes for local variables. Maximum is 16384 bytes.
C:\Users\User\Documents\TH3D_UFW_U1.R2.7 (1)\TH3D_UFW_U1.R2.7\Windows Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\User\Documents\TH3D_UFW_U1.R2.7 (1)\TH3D_UFW_U1.R2.7\Windows Arduino\hardware\tools\avr/etc/avrdude.conf -v -V -patmega1284p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_646198/ArduinoISP.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\User\Documents\TH3D_UFW_U1.R2.7 (1)\TH3D_UFW_U1.R2.7\Windows Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
An error occurred while uploading the sketch
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: Expected signature for ATmega1284P is 1E 97 05
Double check chip, or use -F to override this check.
avrdude done. Thank you.
option enabled in File -> Preferences.
Trying to upload sketch for bootloader on Ender 3.This is the error message. Is there a workaround for this? It says I can use -F but where and is it advisable?
