Hi everyone
I started a thread a few days ago about how my Arduino Duemilanove 328 won't upload any sketches, giving the error:
avrdude: verification error, first mismatch at byte 0x0042
0x79 != 0xa4
avrdude: verification error; content mismatch
I was advised to try reflashing the chip. I might be wrong but I assumed this meant reburning the bootloader.
Following the instructions on http://arduino.cc/en/Hacking/ParallelProgrammer, I built a parallel programmer using a printer connection and parts from a USB internal connector from a PC (the bit that goes to the motherboard).
I tested all the pins with a multimeter, all of them checked out, I also removed all other pins except the ones that were needed so I am sure nothing is shorting out. But for some reason, the programmer doesn't work :(.
Whenever I try to use it I get this error: "Wrong microcontroller. Are you sure you entered proper board under tools?".
I am certain the correct board is selected. I also tried changing the preferences.txt so that it will use the parallel to upload sketches, but that didn't work either.
I have tried multiple computers, new drivers, different leads, and now the parallel programmer, nothing works ![]()
Is there a chance that something other than the ATMega328 is faulty? That might explain why I can't do anything to fix it...
I don't mind ordering a new atmega328 chip, but I wanted to make sure that was likely to be the fault first ![]()
Anyway, I have a few awesome projects in mind including some car displays interfaced with GPS, which will also be able to talk with you via voice recognition (essentially night rider inside a peugeot 106 xD) and a voice controlled robot that can fetch data from the internet (emails, weather) etc. If anybody here figures out what's wrong with my Arduino, then I will be sure to send pics and info to you first when I get them going =D.
Plus I will send a gift wrapped cookie to you. Nobody can turn that down ![]()
