Today I wanted to work with my Arduino again, but every time I want to upload a sketch I get
Sketch uses 11216 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 2384 bytes (7%) of dynamic memory, leaving 30384 bytes for local variables. Maximum is 32768 bytes.
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.base/java.lang.Thread.run(Thread.java:832)
Caused by: processing.app.SerialException: Error touching serial port '/dev/ttyACM0'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - /dev/ttyACM0; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
When I want to open the serial monitor, I also get Error opening serial port '/dev/ttyACM0'. (Port not found)
It worked before and I didn't change anything, so i guess maybe an update broke it. Anyway I'm pretty sure that the port is set correctly
~ >>> ls -l /dev/ttyACM*
crw-rw---- 1 root uucp 166, 0 22. Apr 23:26 /dev/ttyACM0
~ >>> groups
network power users uucp storage lp input audio wheel autologin maeries
I already remove modemmanager
as suggested in this thead Leonardo BareMinimum Upload Failure with Linux
It also works on Windows, thus the Arduino is not broken
System:
- OS is Manjaro Linux
- The Arduino is a Nano IoT
