Can't upload sketches to custom Arduino
Hello everyone,
I recently made my custom Arduino with the help of this tutorial: http://itp.nyu.edu/physcomp/Tutorials/ArduinoBreadboard
I wired everything up like in the tutorial, except the Sparkfun USB to Serial converter, I use the Arduino USB to Serial Converter Light.
Now the problem is that when I try to upload the example Blink sketch, the Arduino IDE 1.0 gives this error:
avrdude: stk500_getsync(): not in sync: resp=0x00
What could be the problem?
I already checked this forum and the internet for solutions, but none of them work. I've installed this driver: http://arduino.cc/en/uploads/Main/Arduino_USBSerial.zip .
If I look in the device manager, the COM is fine and don't needs an update. In the Arduino IDE, I've selected COM 7(it's the right COM) and selected Arduino Uno as my board.
I'm using the ATmega328 chip with the Uno Optiboot(it was already when I bought it).
Maybe the problem is that I don't have the Reset pin connected on the USB2Serial board? Only the TX, RX, 5V and GND are connected.
I've also seen that the led on my custom Arduino doesn't flash if I reset it. And also, the TX and RX leds flash when uploading a sketch.
Things I've tried:
  • Upload the sketch and press Reset with different timing
  • Selecting different boards in the IDE
  • Press reset before uploading the sketch
  • Replacing the ATmega328 with another(also with optiboot) -...
Regards, Tibo
It seems like something is wrong on my custom Arduino. I uploaded the sketch by inserting the chip into my original Arduino Uno, and then it worked. But when I insert the chip in my custom Arduino, then the led doesn't blink...
(deleted)
There should be two pins on the target processor connected to +5V. Are they? When you measure the voltage on each of these two pins is it close to +5V? With the power disconnected, measure the resistance between the +5V pins and the point where +5V is connected to the breadboard. Is the resistance close to zero ohms?
There should be two pins on the target connected to GND. Are they? With the power disconnected, measure the resistance between the GND pins and the point where GND is connected to the breadboard. Is the resistance close to zero ohms?
Are you using a crystal or resonator?
spycatcher2k: Press and hold reset, press upload, when sketch size is shown release reset.
Try That.
No luck with that.
The VCC, AREF and AVCC go to the 5v rail.
VCC is 5v, AREF is 0.35v, AVCC is 0.75v.
Yes
Yes
Yes
A crystal
Thanks for helping me!
“The VCC, AREF and AVCC go to the 5v rail.”
yet
“VCC is 5v, AREF is 0.35v, AVCC is 0.75v.”
Something not right there - all should be 5V.
VCC is 5v, ... AVCC is 0.75v.
measure the resistance between the +5V pins and the point where +5V is connected to the breadboard. Is the resistance close to zero ohms? Yes
That is an impossibility. If your circuit is wired as you claim then VCC and AVCC have to be at the same voltage.
Argh! Ninja'd by CrossRoads!
I’ll take a look at it tomorrow.
Yeah, had a couple minutes free at just the right time it seems!
Ok I see that I've measured it wrong yesterday. Here are the new results:
Yes
With the power disconnected, measure the resistance between the +5V pins and the point where +5V is connected to the breadboard. Is the resistance close to zero ohm?
It is 0 ohm, but on the point where it connects to the breadboard it is 835 ohm. So maybe the socket where the chip is inserted is the problem?
Yes
I checked the wiring again, and everythig is exact the same as in the tutorial.
It’s working!
I found out that it was the socket that was the problem.
Cool.
