Hello everyone. I am new in using Arduino. I am using Arduino MKR WIFI 1010. I have downloaded "wifiNINA" by Arduino. However I am getting errors every time I upload the code to the board. I have tested it using my friend's laptop, it worked properly and the code run without errors.
Here is below the code:
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the Wifi radio's status
//Initialize serial and wait for port to open:
while (!Serial)
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to network: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
Serial.println("----------------------------------------");
printData();
// check the network connection once every 10 seconds:
delay(10000);
printData();
void printData() {
Serial.println("Board Information:");
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println("Network Information:");
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
These are the errors:
In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:267:0,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/Arduino.h:38,
from C:\Users\user\AppData\Local\Temp\arduino\sketches\BB0B12A03DBE629FED4465EE7E0376A2\sketch\sketch_apr5b.ino.cpp:1:
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:182:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t XOSCRDY:1; /!< bit: 0 XOSC Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:183:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t XOSC32KRDY:1; /!< bit: 1 XOSC32K Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:184:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t OSC32KRDY:1; /!< bit: 2 OSC32K Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:185:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t OSC8MRDY:1; /!< bit: 3 OSC8M Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:186:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DFLLRDY:1; /!< bit: 4 DFLL Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:187:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DFLLOOB:1; /!< bit: 5 DFLL Out Of Bounds /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:188:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DFLLLCKF:1; /!< bit: 6 DFLL Lock Fine /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:189:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DFLLLCKC:1; /!< bit: 7 DFLL Lock Coarse /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:190:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DFLLRCS:1; /!< bit: 8 DFLL Reference Clock Stopped /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:191:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t BOD33RDY:1; /!< bit: 9 BOD33 Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:192:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t BOD33DET:1; /!< bit: 10 BOD33 Detection /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:193:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t B33SRDY:1; /!< bit: 11 BOD33 Synchronization Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:194:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t :3; /!< bit: 12..14 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:195:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DPLLLCKR:1; /!< bit: 15 DPLL Lock Rise /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:196:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DPLLLCKF:1; /!< bit: 16 DPLL Lock Fall /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:197:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DPLLLTO:1; /!< bit: 17 DPLL Lock Timeout /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:198:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t :14; /!< bit: 18..31 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:915:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_INTENCLR_Type INTENCLR; /< \brief Offset: 0x00 (R/W 32) Interrupt Enable Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:916:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_INTENSET_Type INTENSET; /< \brief Offset: 0x04 (R/W 32) Interrupt Enable Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:917:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_INTFLAG_Type INTFLAG; /< \brief Offset: 0x08 (R/W 32) Interrupt Flag Status and Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:918:3: error: '__I' does not name a type; did you mean '__N'?
__I SYSCTRL_PCLKSR_Type PCLKSR; /< \brief Offset: 0x0C (R/ 32) Power and Clocks Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:919:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_XOSC_Type XOSC; /< \brief Offset: 0x10 (R/W 16) External Multipurpose Crystal Oscillator (XOSC) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:921:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_XOSC32K_Type XOSC32K; /< \brief Offset: 0x14 (R/W 16) 32kHz External Crystal Oscillator (XOSC32K) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:923:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_OSC32K_Type OSC32K; /< \brief Offset: 0x18 (R/W 32) 32kHz Internal Oscillator (OSC32K) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:924:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_OSCULP32K_Type OSCULP32K; /< \brief Offset: 0x1C (R/W 8) 32kHz Ultra Low Power Internal Oscillator (OSCULP32K) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:926:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_OSC8M_Type OSC8M; /< \brief Offset: 0x20 (R/W 32) 8MHz Internal Oscillator (OSC8M) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:927:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DFLLCTRL_Type DFLLCTRL; /< \brief Offset: 0x24 (R/W 16) DFLL48M Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:929:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DFLLVAL_Type DFLLVAL; /< \brief Offset: 0x28 (R/W 32) DFLL48M Value /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:930:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DFLLMUL_Type DFLLMUL; /< \brief Offset: 0x2C (R/W 32) DFLL48M Multiplier /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:931:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DFLLSYNC_Type DFLLSYNC; /< \brief Offset: 0x30 (R/W 8) DFLL48M Synchronization /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:933:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_BOD33_Type BOD33; /< \brief Offset: 0x34 (R/W 32) 3.3V Brown-Out Detector (BOD33) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:935:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_VREG_Type VREG; /< \brief Offset: 0x3C (R/W 16) Voltage Regulator System (VREG) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:937:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_VREF_Type VREF; /< \brief Offset: 0x40 (R/W 32) Voltage References System (VREF) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:938:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DPLLCTRLA_Type DPLLCTRLA; /< \brief Offset: 0x44 (R/W 8) DPLL Control A /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:940:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DPLLRATIO_Type DPLLRATIO; /< \brief Offset: 0x48 (R/W 32) DPLL Ratio Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:941:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO SYSCTRL_DPLLCTRLB_Type DPLLCTRLB; /< \brief Offset: 0x4C (R/W 32) DPLL Control B /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/sysctrl.h:942:3: error: '__I' does not name a type; did you mean '__N'?
__I SYSCTRL_DPLLSTATUS_Type DPLLSTATUS; /< \brief Offset: 0x50 (R/ 8) DPLL Status /
__N
In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:268:0,
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:420:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t OVF:1; /!< bit: 0 Overflow /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:421:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t ERR:1; /!< bit: 1 Error /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:422:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :1; /!< bit: 2 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:423:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t SYNCRDY:1; /!< bit: 3 Synchronization Ready /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:424:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t MC0:1; /!< bit: 4 Match or Capture Channel 0 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:425:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t MC1:1; /!< bit: 5 Match or Capture Channel 1 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:426:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :2; /!< bit: 6.. 7 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:429:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :4; /!< bit: 0.. 3 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:430:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t MC:2; /!< bit: 4.. 5 Match or Capture Channel x /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:431:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:609:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_CTRLA_Type CTRLA; /< \brief Offset: 0x00 (R/W 16) Control A /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:610:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_READREQ_Type READREQ; /< \brief Offset: 0x02 (R/W 16) Read Request /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:611:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_CTRLBCLR_Type CTRLBCLR; /< \brief Offset: 0x04 (R/W 8) Control B Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:612:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_CTRLBSET_Type CTRLBSET; /< \brief Offset: 0x05 (R/W 8) Control B Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:613:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_CTRLC_Type CTRLC; /< \brief Offset: 0x06 (R/W 8) Control C /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:615:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_DBGCTRL_Type DBGCTRL; /< \brief Offset: 0x08 (R/W 8) Debug Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:617:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_EVCTRL_Type EVCTRL; /< \brief Offset: 0x0A (R/W 16) Event Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:618:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_INTENCLR_Type INTENCLR; /< \brief Offset: 0x0C (R/W 8) Interrupt Enable Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:619:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_INTENSET_Type INTENSET; /< \brief Offset: 0x0D (R/W 8) Interrupt Enable Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:620:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_INTFLAG_Type INTFLAG; /< \brief Offset: 0x0E (R/W 8) Interrupt Flag Status and Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:621:3: error: '__I' does not name a type; did you mean '__N'?
__I TC_STATUS_Type STATUS; /< \brief Offset: 0x0F (R/ 8) Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:622:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT8_COUNT_Type COUNT; /< \brief Offset: 0x10 (R/W 8) COUNT8 Counter Value /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:624:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT8_PER_Type PER; /< \brief Offset: 0x14 (R/W 8) COUNT8 Period Value /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:626:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT8_CC_Type CC[2]; /< \brief Offset: 0x18 (R/W 8) COUNT8 Compare/Capture /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:633:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:634:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:635:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:636:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:637:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:639:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:641:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:642:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:643:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:644:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:645:3: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:646:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT16_COUNT_Type COUNT; /< \brief Offset: 0x10 (R/W 16) COUNT16 Counter Value /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:648:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT16_CC_Type CC[2]; /< \brief Offset: 0x18 (R/W 16) COUNT16 Compare/Capture /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:655:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:656:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:657:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:658:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:659:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:661:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:663:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:664:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:665:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:666:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:667:3: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:668:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT32_COUNT_Type COUNT; /< \brief Offset: 0x10 (R/W 32) COUNT32 Counter Value /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tc.h:670:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TC_COUNT32_CC_Type CC[2]; /< \brief Offset: 0x18 (R/W 32) COUNT32 Compare/Capture /
__tm
In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:269:0,
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:974:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t OVF:1; /!< bit: 0 Overflow /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:975:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t TRG:1; /!< bit: 1 Retrigger /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:976:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t CNT:1; /!< bit: 2 Counter /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:977:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t ERR:1; /!< bit: 3 Error /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:978:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t :7; /!< bit: 4..10 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:979:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t DFS:1; /!< bit: 11 Non-Recoverable Debug Fault /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:980:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t FAULTA:1; /!< bit: 12 Recoverable Fault A /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:981:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t FAULTB:1; /!< bit: 13 Recoverable Fault B /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:982:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t FAULT0:1; /!< bit: 14 Non-Recoverable Fault 0 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:983:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t FAULT1:1; /!< bit: 15 Non-Recoverable Fault 1 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:984:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t MC0:1; /!< bit: 16 Match or Capture 0 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:985:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t MC1:1; /!< bit: 17 Match or Capture 1 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:986:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t MC2:1; /!< bit: 18 Match or Capture 2 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:987:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t MC3:1; /!< bit: 19 Match or Capture 3 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:988:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t :12; /!< bit: 20..31 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:991:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t :16; /!< bit: 0..15 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:992:5: error: '__I' does not name a type; did you mean '__N'?
__I uint32_t MC:4; /!< bit: 16..19 Match or Capture x /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:993:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1783:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_CTRLA_Type CTRLA; /< \brief Offset: 0x00 (R/W 32) Control A /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1784:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_CTRLBCLR_Type CTRLBCLR; /< \brief Offset: 0x04 (R/W 8) Control B Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1785:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_CTRLBSET_Type CTRLBSET; /< \brief Offset: 0x05 (R/W 8) Control B Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1787:3: error: '__I' does not name a type; did you mean '__N'?
__I TCC_SYNCBUSY_Type SYNCBUSY; /< \brief Offset: 0x08 (R/ 32) Synchronization Busy /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1788:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_FCTRLA_Type FCTRLA; /< \brief Offset: 0x0C (R/W 32) Recoverable Fault A Configuration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1789:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_FCTRLB_Type FCTRLB; /< \brief Offset: 0x10 (R/W 32) Recoverable Fault B Configuration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1790:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_WEXCTRL_Type WEXCTRL; /< \brief Offset: 0x14 (R/W 32) Waveform Extension Configuration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1791:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_DRVCTRL_Type DRVCTRL; /< \brief Offset: 0x18 (R/W 32) Driver Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1793:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_DBGCTRL_Type DBGCTRL; /< \brief Offset: 0x1E (R/W 8) Debug Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1795:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_EVCTRL_Type EVCTRL; /< \brief Offset: 0x20 (R/W 32) Event Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1796:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_INTENCLR_Type INTENCLR; /< \brief Offset: 0x24 (R/W 32) Interrupt Enable Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1797:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_INTENSET_Type INTENSET; /< \brief Offset: 0x28 (R/W 32) Interrupt Enable Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1798:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_INTFLAG_Type INTFLAG; /< \brief Offset: 0x2C (R/W 32) Interrupt Flag Status and Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1799:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_STATUS_Type STATUS; /< \brief Offset: 0x30 (R/W 32) Status /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1800:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_COUNT_Type COUNT; /< \brief Offset: 0x34 (R/W 32) Count /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1801:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_PATT_Type PATT; /< \brief Offset: 0x38 (R/W 16) Pattern /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1803:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_WAVE_Type WAVE; /< \brief Offset: 0x3C (R/W 32) Waveform Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1804:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_PER_Type PER; /< \brief Offset: 0x40 (R/W 32) Period /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1805:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_CC_Type CC[4]; /< \brief Offset: 0x44 (R/W 32) Compare and Capture /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1807:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_PATTB_Type PATTB; /< \brief Offset: 0x64 (R/W 16) Pattern Buffer /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1809:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_WAVEB_Type WAVEB; /< \brief Offset: 0x68 (R/W 32) Waveform Control Buffer /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1810:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_PERB_Type PERB; /< \brief Offset: 0x6C (R/W 32) Period Buffer /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/tcc.h:1811:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO TCC_CCB_Type CCB[4]; /< \brief Offset: 0x70 (R/W 32) Compare and Capture Buffer /
__tm
In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:270:0,
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:634:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t SUSPEND:1; /!< bit: 0 Suspend /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:635:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t MSOF:1; /!< bit: 1 Micro Start of Frame in High Speed Mode /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:636:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t SOF:1; /!< bit: 2 Start Of Frame /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:637:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t EORST:1; /!< bit: 3 End of Reset /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:638:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t WAKEUP:1; /!< bit: 4 Wake Up /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:639:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t EORSM:1; /!< bit: 5 End Of Resume /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:640:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t UPRSM:1; /!< bit: 6 Upstream Resume /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:641:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t RAMACER:1; /!< bit: 7 Ram Access /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:642:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t LPMNYET:1; /!< bit: 8 Link Power Management Not Yet /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:643:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t LPMSUSP:1; /!< bit: 9 Link Power Management Suspend /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:644:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t :6; /!< bit: 10..15 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:679:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t :2; /!< bit: 0.. 1 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:680:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t HSOF:1; /!< bit: 2 Host Start Of Frame /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:681:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t RST:1; /!< bit: 3 Bus Reset /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:682:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:683:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t DNRSM:1; /!< bit: 5 Downstream /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:684:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t UPRSM:1; /!< bit: 6 Upstream Resume from the Device /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:685:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:686:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t DCONN:1; /!< bit: 8 Device Connection /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:687:5: error: '__I' does not name a type; did you mean '__N'?
__I uint16_t DDISC:1; /!< bit: 9 Device Disconnection /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:688:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1156:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRCPT0:1; /!< bit: 0 Transfer Complete 0 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1157:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRCPT1:1; /!< bit: 1 Transfer Complete 1 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1158:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRFAIL0:1; /!< bit: 2 Error Flow 0 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1159:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRFAIL1:1; /!< bit: 3 Error Flow 1 /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1160:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t RXSTP:1; /!< bit: 4 Received Setup /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1161:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t STALL0:1; /!< bit: 5 Stall 0 In/out /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1162:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t STALL1:1; /!< bit: 6 Stall 1 In/out /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1163:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :1; /!< bit: 7 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1166:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRCPT:2; /!< bit: 0.. 1 Transfer Complete x /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1167:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRFAIL:2; /!< bit: 2.. 3 Error Flow x /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1168:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :1; /!< bit: 4 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1169:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t STALL:2; /!< bit: 5.. 6 Stall x In/out /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1170:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1208:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRCPT0:1; /!< bit: 0 Transfer Complete 0 Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1209:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRCPT1:1; /!< bit: 1 Transfer Complete 1 Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1210:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRFAIL:1; /!< bit: 2 Error Flow Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1211:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t PERR:1; /!< bit: 3 Pipe Error Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1212:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TXSTP:1; /!< bit: 4 Transmit Setup Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1213:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t STALL:1; /!< bit: 5 Stall Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1214:5: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1217:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t TRCPT:2; /!< bit: 0.. 1 Transfer Complete x Interrupt Flag /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1218:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :6; /!< bit: 2.. 7 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1665:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_ADDR_Type ADDR; /< \brief Offset: 0x000 (R/W 32) DEVICE_DESC_BANK Endpoint Bank, Adress of Data Buffer /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1666:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_PCKSIZE_Type PCKSIZE; /< \brief Offset: 0x004 (R/W 32) DEVICE_DESC_BANK Endpoint Bank, Packet Size /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1667:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_EXTREG_Type EXTREG; /< \brief Offset: 0x008 (R/W 16) DEVICE_DESC_BANK Endpoint Bank, Extended /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1668:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_STATUS_BK_Type STATUS_BK; /< \brief Offset: 0x00A (R/W 8) DEVICE_DESC_BANK Enpoint Bank, Status of Bank /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1676:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_ADDR_Type ADDR; /< \brief Offset: 0x000 (R/W 32) HOST_DESC_BANK Host Bank, Adress of Data Buffer /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1677:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_PCKSIZE_Type PCKSIZE; /< \brief Offset: 0x004 (R/W 32) HOST_DESC_BANK Host Bank, Packet Size /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1678:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_EXTREG_Type EXTREG; /< \brief Offset: 0x008 (R/W 16) HOST_DESC_BANK Host Bank, Extended /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1679:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_STATUS_BK_Type STATUS_BK; /< \brief Offset: 0x00A (R/W 8) HOST_DESC_BANK Host Bank, Status of Bank /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1681:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_CTRL_PIPE_Type CTRL_PIPE; /< \brief Offset: 0x00C (R/W 16) HOST_DESC_BANK Host Bank, Host Control Pipe /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1682:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_STATUS_PIPE_Type STATUS_PIPE; /< \brief Offset: 0x00E (R/W 16) HOST_DESC_BANK Host Bank, Host Status Pipe /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1689:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_EPCFG_Type EPCFG; /< \brief Offset: 0x000 (R/W 8) DEVICE_ENDPOINT End Point Configuration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1691:3: error: '__O' does not name a type; did you mean '__N'?
__O USB_DEVICE_EPSTATUSCLR_Type EPSTATUSCLR; /< \brief Offset: 0x004 ( /W 8) DEVICE_ENDPOINT End Point Pipe Status Clear /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1692:3: error: '__O' does not name a type; did you mean '__N'?
__O USB_DEVICE_EPSTATUSSET_Type EPSTATUSSET; /< \brief Offset: 0x005 ( /W 8) DEVICE_ENDPOINT End Point Pipe Status Set /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1693:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_DEVICE_EPSTATUS_Type EPSTATUS; /< \brief Offset: 0x006 (R/ 8) DEVICE_ENDPOINT End Point Pipe Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1694:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_EPINTFLAG_Type EPINTFLAG; /< \brief Offset: 0x007 (R/W 8) DEVICE_ENDPOINT End Point Interrupt Flag /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1695:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_EPINTENCLR_Type EPINTENCLR; /< \brief Offset: 0x008 (R/W 8) DEVICE_ENDPOINT End Point Interrupt Clear Flag /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1696:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_EPINTENSET_Type EPINTENSET; /< \brief Offset: 0x009 (R/W 8) DEVICE_ENDPOINT End Point Interrupt Set Flag /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1704:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_PCFG_Type PCFG; /< \brief Offset: 0x000 (R/W 8) HOST_PIPE End Point Configuration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1706:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_BINTERVAL_Type BINTERVAL; /< \brief Offset: 0x003 (R/W 8) HOST_PIPE Bus Access Period of Pipe /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1707:3: error: '__O' does not name a type; did you mean '__N'?
__O USB_HOST_PSTATUSCLR_Type PSTATUSCLR; /< \brief Offset: 0x004 ( /W 8) HOST_PIPE End Point Pipe Status Clear /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1708:3: error: '__O' does not name a type; did you mean '__N'?
__O USB_HOST_PSTATUSSET_Type PSTATUSSET; /< \brief Offset: 0x005 ( /W 8) HOST_PIPE End Point Pipe Status Set /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1709:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_HOST_PSTATUS_Type PSTATUS; /< \brief Offset: 0x006 (R/ 8) HOST_PIPE End Point Pipe Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1710:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_PINTFLAG_Type PINTFLAG; /< \brief Offset: 0x007 (R/W 8) HOST_PIPE Pipe Interrupt Flag /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1711:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_PINTENCLR_Type PINTENCLR; /< \brief Offset: 0x008 (R/W 8) HOST_PIPE Pipe Interrupt Flag Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1712:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_PINTENSET_Type PINTENSET; /< \brief Offset: 0x009 (R/W 8) HOST_PIPE Pipe Interrupt Flag Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1720:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_CTRLA_Type CTRLA; /< \brief Offset: 0x000 (R/W 8) Control A /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1722:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_SYNCBUSY_Type SYNCBUSY; /< \brief Offset: 0x002 (R/ 8) Synchronization Busy /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1723:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_QOSCTRL_Type QOSCTRL; /< \brief Offset: 0x003 (R/W 8) USB Quality Of Service /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1725:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_CTRLB_Type CTRLB; /< \brief Offset: 0x008 (R/W 16) DEVICE Control B /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1726:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_DADD_Type DADD; /< \brief Offset: 0x00A (R/W 8) DEVICE Device Address /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1728:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_DEVICE_STATUS_Type STATUS; /< \brief Offset: 0x00C (R/ 8) DEVICE Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1729:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_FSMSTATUS_Type FSMSTATUS; /< \brief Offset: 0x00D (R/ 8) Finite State Machine Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1731:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_DEVICE_FNUM_Type FNUM; /< \brief Offset: 0x010 (R/ 16) DEVICE Device Frame Number /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1733:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_INTENCLR_Type INTENCLR; /< \brief Offset: 0x014 (R/W 16) DEVICE Device Interrupt Enable Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1735:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_INTENSET_Type INTENSET; /< \brief Offset: 0x018 (R/W 16) DEVICE Device Interrupt Enable Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1737:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DEVICE_INTFLAG_Type INTFLAG; /< \brief Offset: 0x01C (R/W 16) DEVICE Device Interrupt Flag /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1739:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_DEVICE_EPINTSMRY_Type EPINTSMRY; /< \brief Offset: 0x020 (R/ 16) DEVICE End Point Interrupt Summary /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1741:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_DESCADD_Type DESCADD; /< \brief Offset: 0x024 (R/W 32) Descriptor Address /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1742:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_PADCAL_Type PADCAL; /< \brief Offset: 0x028 (R/W 16) USB PAD Calibration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1751:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1753:3: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1754:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1756:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_CTRLB_Type CTRLB; /< \brief Offset: 0x008 (R/W 16) HOST Control B /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1757:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_HSOFC_Type HSOFC; /< \brief Offset: 0x00A (R/W 8) HOST Host Start Of Frame Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1759:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_STATUS_Type STATUS; /< \brief Offset: 0x00C (R/W 8) HOST Status /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1760:3: error: '__I' does not name a type; did you mean '__N'?
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1762:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_FNUM_Type FNUM; /< \brief Offset: 0x010 (R/W 16) HOST Host Frame Number /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1763:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_HOST_FLENHIGH_Type FLENHIGH; /< \brief Offset: 0x012 (R/ 8) HOST Host Frame Length /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1765:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_INTENCLR_Type INTENCLR; /< \brief Offset: 0x014 (R/W 16) HOST Host Interrupt Enable Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1767:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_INTENSET_Type INTENSET; /< \brief Offset: 0x018 (R/W 16) HOST Host Interrupt Enable Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1769:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO USB_HOST_INTFLAG_Type INTFLAG; /< \brief Offset: 0x01C (R/W 16) HOST Host Interrupt Flag /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1771:3: error: '__I' does not name a type; did you mean '__N'?
__I USB_HOST_PINTSMRY_Type PINTSMRY; /< \brief Offset: 0x020 (R/ 16) HOST Pipe Interrupt Summary /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1773:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/usb.h:1774:3: error: '__IO' does not name a type; did you mean '__tm'?
__tm
In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:271:0,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/Arduino.h:38,
from C:\Users\user\AppData\Local\Temp\arduino\sketches\BB0B12A03DBE629FED4465EE7E0376A2\sketch\sketch_apr5b.ino.cpp:1:
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:234:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t EW:1; /!< bit: 0 Early Warning /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:235:5: error: '__I' does not name a type; did you mean '__N'?
__I uint8_t :7; /!< bit: 1.. 7 Reserved /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:289:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO WDT_CTRL_Type CTRL; /< \brief Offset: 0x0 (R/W 8) Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:290:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO WDT_CONFIG_Type CONFIG; /< \brief Offset: 0x1 (R/W 8) Configuration /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:291:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO WDT_EWCTRL_Type EWCTRL; /< \brief Offset: 0x2 (R/W 8) Early Warning Interrupt Control /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:293:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO WDT_INTENCLR_Type INTENCLR; /< \brief Offset: 0x4 (R/W 8) Interrupt Enable Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:294:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO WDT_INTENSET_Type INTENSET; /< \brief Offset: 0x5 (R/W 8) Interrupt Enable Set /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:295:3: error: '__IO' does not name a type; did you mean '__tm'?
__IO WDT_INTFLAG_Type INTFLAG; /< \brief Offset: 0x6 (R/W 8) Interrupt Flag Status and Clear /
__tm
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:296:3: error: '__I' does not name a type; did you mean '__N'?
__I WDT_STATUS_Type STATUS; /< \brief Offset: 0x7 (R/ 8) Status /
__N
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/component/wdt.h:297:3: error: '__O' does not name a type; did you mean '__N'?
__O WDT_CLEAR_Type CLEAR; /< \brief Offset: 0x8 ( /W 8) Clear /
__N
In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/SafeRingBuffer.h:25:0,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/Uart.h:23,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrwifi1010/variant.h:165,
from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/Arduino.h:51,
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h: In constructor '__Guard::__Guard()':
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:12:22: error: '__get_PRIMASK' was not declared in this scope
__Guard() : primask(__get_PRIMASK()), loops(1) {
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:12:22: note: suggested alternative: '__PRIMAX'
__PRIMAX
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:13:3: error: '__disable_irq' was not declared in this scope
__disable_irq();
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:13:3: note: suggested alternative: 'uhd_disable_sof'
__disable_irq();
uhd_disable_sof
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h: In destructor '__Guard::~__Guard()':
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:17:4: error: '__enable_irq' was not declared in this scope
__enable_irq();
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:17:4: note: suggested alternative: '_rename_r'
__enable_irq();
_rename_r
C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/sync.h:19:4: error: '__ISB' was not declared in this scope
__ISB();
exit status 1
Compilation error: exit status 1
Anyone can help me solve this please?
