Can't upload the program to Arduino UNO robot
my code(for robotic arm car bluetooth controlled) is done compiling with no errors.....but it was not uploaded to the arduino board showing errors:::::
Arduino: 1.8.5 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Archiving built core (caching) in: C:\Users\neelav\AppData\Local\Temp\arduino_cache_395155\core\core_arduino_avr_pro_cpu_16MHzatmega328_c521b3af8cfed15f0972e50d014fdd79.a
Sketch uses 4124 bytes (13%) of program storage space. Maximum is 30720 bytes.
Global variables use 383 bytes (18%) of dynamic memory, leaving 1665 bytes for local variables. Maximum is 2048 bytes.
C:\Users\neelav\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\neelav\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b57600 -D -Uflash:w:C:\Users\neelav\AppData\Local\Temp\arduino_build_590514/BT.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\neelav\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb3
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
help if anyone knows the solution
Topic split.
Please dont just jump on other posts.
Also read the sticky posts at the top of the forum.
Bob.
Uno or Pro Mini?
Pick the right Com Port. Com1 isn't right.
Is COM1 the correct port? If it is, what do you use to program it? USB-to-TTL adapter? If so, with DTR connected to reset?
