Can't upload the program to the board
Hi! Please HELP!
In the editor I can choose the board and port, and I can use serial monitor.
I can't upload the program to the Arduino Nano (CH340G) over USB. I tried upload with AVRmkII programmer too.
I tried on Win10, Win7. But always got this erorr message:
Using Port : COM16
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x88
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x48
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x08
avrdude done. Thank you.
Executing command: exit status 1
Hi @bocsizsolt,
I think it's possible that you are not selecting the correct flavour between ATmega168 and ATmega328, please select the other one and try again, let us know if it works
Thanks
Hi!
Thanks for your answer!
I selected Atmega328 but not helped. Can't upload over USB or AVRmkII :frowning:
Are you by any chance using USB 3.0 ports ?
Is so then inserting a POWERED USB 2.0 hub between the computer and the Arduino in question may help.
hi i am also having the same problem but in online ide web editor it says that pluggin is not connected but i have launched it many times and downloaded it 2 times.
pl. help...............
Deepa please start your own thread and include the details.
If you are unsure what ti include please read this thread
