I have been working with the ESP32 for about 6 weeks now, and I keep discovering things -- a real learning curve. However, today I tried attaching an bicolor LED to two pins, common anode, so the LED's are on when the pins are low. The LED lights up before the program is downloaded, so I assume the pins (GPOI 2 and GPIO 4) are low in their unprogrammed state.
Here's the rub. The code will not upload when the LED's are attached. ("Timed out waiting for packet content) I used a 1K resistor for current limiting, so only a few milliamps should be sunk by the ESP32 when the LED's are on. If I disconnect the LED's the code loads, and if I then reconnect the LED's the program functions fine.
I have tried this on the HelTec WiFi Kit 32, and another board from ezSBC. Same problem.
To the best of my knowledge, any GPIO pin can be used as a simple digital I/O pin. The Heltec board does reserve pins 4, 15, and 16 for the OLED. I also understand that the ADC2 circuitry is not available when WiFi is operational. Pins 4 and 2 are not attachable to ADC2. In any event, when uploading code, I would not expect any of the pins to be active at all, except Tx/Rx and maybe Reset. Somehow, this seems more like a power shortage problem, but I am using a 2 Amp 5v. source to power the boards.
jrdoner:
To the best of my knowledge, that is just not true.
You need to be careful what you connect to various pins; some are input only, some dont have internal pullups, some are on (or off) during sleep, some pulse when going into sleep etc. Plus, what some pins are wired to can affect operation and program upload of the ESP32.
So what did you find happened;
When the LEDs are attached to another pin and GPIO2 is left alone ?
What happens to program upload, when nothing is connected and GPIO2 is connected to ground ?
What happens to program upload, when nothing is connected and GPIO2 is connected to VCC ?
Yeah, ok, fine.
Then here's what.
I too (like you jrdoner) have an ezSBC ESP32 and I uploaded the following sketch, with the LEDs connected -- Zero Problems --
So, with the Red to GPIO2 and Yellow to GPIO4, it won't Upload. BUT. . .
with the Red to GPIO4 and Yellow to GPIO2, It Uploads.
(Red w/ 240Ω, Yel w/ 270Ω)
But that isn't exactly so though.
It can be "held high" - but at some point it cannot.
As I noted in my previous, with the Yel+270Ω connected to GPIO2 it does Upload (whether the Red is on GPIO4 or not).
Sure, I found the 'odd' behaviour with GPIO2 quite some time back, and whilst the data sheet mentions that GPIO2 is a 'strapping pin', as does Kolbans manual, the implications are perhaps not made very clear.
At the time I made a note;
2 Output, shared with the LED on some boards. LED to ground OK, dont let pin be pulled high. Used by pSRAM option when fitted.
