Hi there! This is my first question on the forum. I started with Arduino and the ESP8266 yesterday and am running into the same error each time i try to upload something to the board:
Arduino: 1.8.12 (Linux), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new can abort), All SSL ciphers (most compatible), no dtr (aka ck), 26 MHz, 40MHz, DOUT (compatible), 512KB (FS:none OTA:~246KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
Executable segment sizes:
IROM : 227612 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26768 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 672 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 256304 bytes (51%) of program storage space. Maximum is 499696 bytes.
Global variables use 26804 bytes (32%) of dynamic memory, leaving 55116 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "/root/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "/root/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 2890, in main
esp.connect(args.before)
File "/root/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
option enabled in File -> Preferences.
I set up everything following these to guides:
The board is an ESP-01 and to upload my sketches i use a USB-to-ESP8266-Board. The linked articles are exactly the ones in use.
I already read this thread, but downgrading the library didn't solve my issue. I put a pulldown-resistor between GPIO0 and GND to put the board in programming mode.
Also, i see a blue LED flashing while i upload the sketch (which as i understand it signals, that there is some kind of communication), but the error persists.
I use Arduino on Linux. The USB-Programmer is registered as /dev/USBtty0 and lsusb shows it as QinHeng Electronics HL-340 USB-Serial adapter.
Can someone guide me to a solution or suggest something for me to try out? I'll be happy to provide more information if needed.
Thanks!
