Can't upload to my board
I have windows 7 64bit my arduino is a arduino duemilanove chip ATMEGA 328P
this is my error i get when i upload
Binary sketch size: 12208 bytes (of a 14336 byte maximum)
C:\Users\gamefreak\Desktop\arduino-0018\hardware/tools/avr/bin/avrdude -CC:\Users\gamefreak\Desktop\arduino-0018\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P\\.\COM1 -b19200 -D -Uflash:w:C:\Users\GAMEFR~1\AppData\Local\Temp\build4539364101012093723.tmp\sketch_jul19a.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "C:\Users\gamefreak\Desktop\arduino-0018\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM1
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 19200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
Hey, I thought the duemilanove with 328 chip has a bootloader that runs at 115200 baud rate but you're possibly using 19200 rate. This could explain the "not in sync" error.
how do i change the baut rate ? when i add Serial.begin(115200); i get the follow error : error: expected constructor, destructor, or type conversion before '.' token
Where did you add the Serial.begin() call? In setup(), or outside of setup()?
/* Code starts here - call it GPSLogger_v2.1 :) */
// this is a generic logger that does checksum testing so the data written should be always good
// Assumes a sirf III chipset logger attached to pin 0 and 1
#include "AF_SDLog.h"
#include "util.h"
#include <avr/pgmspace.h>
#include <avr/sleep.h>
// power saving modes
#define SLEEPDELAY 0
#define TURNOFFGPS 0
#define LOG_RMC_FIXONLY 1
AF_SDLog card;
File f;
#define led1Pin 4
#define led2Pin 3
#define powerPin 2
#define BUFFSIZE 75
char buffer[BUFFSIZE];
uint8_t bufferidx = 0;
uint8_t fix = 0; // current fix data
uint8_t i;
/* EXAMPLE
$PSRF103,<msg>,<mode>,<rate>,<cksumEnable>*CKSUM<CR><LF>
<msg> 00=GGA,01=GLL,02=GSA,03=GSV,04=RMC,05=VTG
<mode> 00=SetRate,01=Query
<rate> Output every <rate>seconds, off=00,max=255
<cksumEnable> 00=disable Checksum,01=Enable checksum for specified message
Note: checksum is required
Example 1: Query the GGA message with checksum enabled
$PSRF103,00,01,00,01*25
Example 2: Enable VTG message for a 1Hz constant output with checksum enabled
$PSRF103,05,00,01,01*20
Example 3: Disable VTG message
$PSRF103,05,00,00,01*21
#define SERIAL_SET   "$PSRF100,01,4800,08,01,00*0E\r\n"
// GGA-Global Positioning System Fixed Data, message 103,00
#define LOG_GGA 0
#define GGA_ON   "$PSRF103,00,00,01,01*25\r\n"
#define GGA_OFF  "$PSRF103,00,00,00,01*24\r\n"
// GLL-Geographic Position-Latitude/Longitude, message 103,01
#define LOG_GLL 0
#define GLL_ON   "$PSRF103,01,00,01,01*26\r\n"
#define GLL_OFF  "$PSRF103,01,00,00,01*27\r\n"
// GSA-GNSS DOP and Active Satellites, message 103,02
#define LOG_GSA 0
#define GSA_ON   "$PSRF103,02,00,01,01*27\r\n"
#define GSA_OFF  "$PSRF103,02,00,00,01*26\r\n"
// GSV-GNSS Satellites in View, message 103,03
#define LOG_GSV 0
#define GSV_ON   "$PSRF103,03,00,01,01*26\r\n"
#define GSV_OFF  "$PSRF103,03,00,00,01*27\r\n"
// RMC-Recommended Minimum Specific GNSS Data, message 103,04
#define LOG_RMC 1
#define RMC_ON   "$PSRF103,04,00,01,01*21\r\n"
#define RMC_OFF  "$PSRF103,04,00,00,01*20\r\n"
// VTG-Course Over Ground and Ground Speed, message 103,05
#define LOG_VTG 0
#define VTG_ON   "$PSRF103,05,00,01,01*20\r\n"
#define VTG_OFF  "$PSRF103,05,00,00,01*21\r\n"
// Switch Development Data Messages On/Off, message 105
#define LOG_DDM 1
#define DDM_ON   "$PSRF105,01*3E\r\n"
#define DDM_OFF  "$PSRF105,00*3F\r\n"
#define USE_WAAS   0     // useful in US, but slower fix
#define WAAS_ON    "$PSRF151,01*3F\r\n"       // the command for turning on WAAS
#define WAAS_OFF   "$PSRF151,00*3E\r\n"       // the command for turning off WAAS
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
  if (c < '0')
    return 0;
  if (c <= '9')
    return c - '0';
  if (c < 'A')
    return 0;
  if (c <= 'F')
    return (c - 'A')+10;
// blink out an error code
void error(uint8_t errno) {
  while(1) {
    for (i=0; i<errno; i++) {
      digitalWrite(led1Pin, HIGH);
      digitalWrite(led2Pin, HIGH);
      delay(100);
      digitalWrite(led1Pin, LOW);
      digitalWrite(led2Pin, LOW);
      delay(100);
    for (; i<10; i++) {
      delay(200);
  WDTCSR |= (1 << WDCE) | (1 << WDE);
  WDTCSR = 0;
  Serial.begin(4800);
  putstring_nl("\r\nGPSlogger");
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(powerPin, OUTPUT);
  digitalWrite(powerPin, LOW);
  if (!card.init_card()) {
    putstring_nl("Card init. failed!");
    error(1);
  if (!card.open_partition()) {
    putstring_nl("No partition!");
    error(2);
  if (!card.open_filesys()) {
    putstring_nl("Can't open filesys");
    error(3);
  if (!card.open_dir("/")) {
    putstring_nl("Can't open /");
    error(4);
  strcpy(buffer, "GPSLOG00.TXT");
  for (buffer[6] = '0'; buffer[6] <= '9'; buffer[6]++) {
    for (buffer[7] = '0'; buffer[7] <= '9'; buffer[7]++) {
      //putstring("\ntrying to open ");Serial.println(buffer);
      f = card.open_file(buffer);
      if (!f)
      card.close_file(f);
    if (!f)
  if(!card.create_file(buffer)) {
    putstring("couldnt create ");
    error(5);
  if (!f) {
    putstring("error opening ");
    card.close_file(f);
    error(6);
  putstring("writing to ");
  putstring_nl("ready!");
  putstring(SERIAL_SET);
  delay(250);
  if (LOG_DDM)
    putstring(DDM_ON);
    putstring(DDM_OFF);
  delay(250);
  if (LOG_GGA)
    putstring(GGA_ON);
    putstring(GGA_OFF);
  delay(250);
  if (LOG_GLL)
    putstring(GLL_ON);
    putstring(GLL_OFF);
  delay(250);
  if (LOG_GSA)
    putstring(GSA_ON);
    putstring(GSA_OFF);
  delay(250);
  if (LOG_GSV)
    putstring(GSV_ON);
    putstring(GSV_OFF);
  delay(250);
  if (LOG_RMC)
    putstring(RMC_ON);
    putstring(RMC_OFF);
  delay(250);
  if (LOG_VTG)
    putstring(VTG_ON);
    putstring(VTG_OFF);
  delay(250);
  if (USE_WAAS)
    putstring(WAAS_ON);
    putstring(WAAS_OFF);
  //Serial.println(Serial.available(), DEC);
  char c;
  uint8_t sum;
  // read one 'line'
  if (Serial.available()) {
    c = Serial.read();
    //Serial.print(c, BYTE);
    if (bufferidx == 0) {
      while (c != '
       c = Serial.read(); // wait till we get a $
   buffer[bufferidx] = c;
   if (c == ‘\n’) {
     //putstring_nl(“EOL”);
     //Serial.print(buffer);
     buffer[bufferidx+1] = 0; // terminate it
if (buffer[bufferidx-4] != ‘’) {
       // no checksum?
       Serial.print(’
’, BYTE);
       bufferidx = 0;
       return;
     // get checksum
     sum = parseHex(buffer[bufferidx-3]) * 16;
     sum += parseHex(buffer[bufferidx-2]);
// check checksum
     for (i=1; i < (bufferidx-4); i++) {
       sum ^= buffer[i];
     if (sum != 0) {
       //putstring_nl(“Cxsum mismatch”);
       Serial.print(’~’, BYTE);
       bufferidx = 0;
       return;
     // got good data!
if (strstr(buffer, “GPRMC”)) {
       // find out if we got a fix
       char *p = buffer;
       p = strchr(p, ‘,’)+1;
       p = strchr(p, ‘,’)+1;       // skip to 3rd item
if (p[0] == ‘V’) {
         fix = 0;
         fix = 1;
     if (LOG_RMC_FIXONLY) {
       if (!fix) {
         Serial.print(’_’, BYTE);
         bufferidx = 0;
         return;
     // rad. lets log it!
     Serial.print(’#’, BYTE);
     digitalWrite(led2Pin, HIGH);      // sets the digital pin as output
if(card.write_file(f, (uint8_t *) buffer, bufferidx) != bufferidx) {
        putstring_nl(“can’t write!”);
   return;
bufferidx = 0;
// turn off GPS module?
     if (TURNOFFGPS) {
       digitalWrite(powerPin, HIGH);
sleep_sec(SLEEPDELAY);
     return;
   bufferidx++;
   if (bufferidx == BUFFSIZE-1) {
      Serial.print(’!’, BYTE);
      bufferidx = 0;
void sleep_sec(uint8_t x) {
 while (x–) {
    // set the WDT to wake us up!
   WDTCSR |= (1 << WDCE) | (1 << WDE); // enable watchdog & enable changing it
   WDTCSR = (1<< WDE) | (1 <<WDP2) | (1 << WDP1);
   WDTCSR |= (1<< WDIE);
   set_sleep_mode(SLEEP_MODE_PWR_DOWN);
   sleep_enable();
   sleep_mode();
   sleep_disable();
SIGNAL(WDT_vect) {
 WDTCSR = 0;
/* End code */
this is my code i downloaded from adafruit.com normaly it need to work
