Well, I just got a brand new LilyPad yesterday. I've tried EVERYthing, but I've had absolutely no luck uploading to it.
I'm using the FT232RL Arduino Serial USB Board. This link shows how I've got it hooked up:
The LED on pin 13 blinks rapidly three times when power is first applied, then repeats at a regular interval after that. The LED also blinks rapidly directly after the reset button is pressed. I assume this indicates that the boot loader is running. This is the only thing that lights up on the LilyPad itself. The TX and RX lights on the USB Board blink for a bit directly after I attempt to upload a sketch.
I've tried varying the timing, pushing the reset button both before and after I click the icon to upload the Blink demo sketch. I've also tried switching the alligator clips to the RX and TX pads, all to no avail. I've tried this with an Intel Mac, a G4, and with a PC running Windows XP. I've gone over all the connections very carefully with my multimeter. It looks like everything is solid and that there are no shorts.
Does anyone have any ideas? Is it possible I've got a dead pin on the processor itself?
Could the output the environment spews out give some hint as to whether the problem is with the serial board or with the LilyPad? I'll include it in a follow up post in hopes that it might make sense to someone.
Thanks for any help you can give me!
Jason
