I've recently bought a knockoff arduino nano from a local webshop, and i cant get it to work. I've been trying numerous solutions online but so far nothing has worked. When i try to upoload a sketch (blank), it takes a few minutes and eventually shows me it has tried 10 times without being able to communicate with the board. When powering up, the red L light flashes 7 times quickly, and afterwards flashes indefinitely every 2 or so seconds.
The arduino is named "Nano V3.0"
It has an FTDI chip and connects to my pc via usb just fine. To clear out some possibilites i'll tell you how my IDE is set up at the moment:
- The board that i selected in the IDE is "Arduino Nano"
- The processor that i selected in the IDE is "ATmega328P (Old bootloader)"
- The port that i slected in the IDE is "COM4" (wich i have verified is the right port, through device manager.)
- I have tried just about every programmer. (even though i have heard it doesn't matter if you dont use the 'upload using programmer option'. Though i do get different errors when changing it and using the upload button.)
When i try to upload a sketch, the RX light flashes 3 times, and then does nothing for the remainder of the upload. Also when sending something using the serial monitor, the RX light also flashes.
Here's the error report:
Arduino: 1.8.10 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createTempFile(File.java:2024)
at processing.app.BaseNoGui.saveFile(BaseNoGui.java:886)
at processing.app.SketchFile.save(SketchFile.java:287)
at processing.app.Sketch.save(Sketch.java:138)
at processing.app.SketchController.save(SketchController.java:352)
at processing.app.Editor.handleSave2(Editor.java:1928)
at processing.app.Editor.handleSave(Editor.java:1903)
at processing.app.Editor.handleExport(Editor.java:2043)
at processing.app.EditorToolbar.handleSelectionPressed(EditorToolbar.java:498)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:448)
at java.awt.Component.processMouseEvent(Component.java:6536)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4532)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Access is denied
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x53
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Thank you for reading my post! If i'm missing any information you need, feel free to ask.
