can't upload tp arduino 101
This is a new board. I cannot load code.
  1. loaded IDE 1.6.7
  2. loaded curie code from board manager
  3. set to arduino, my port
Setup works perfectly with Uno board, same code.
Please turn on verbose output in File > Preferences and past the output in the console when you try to upload here.
I'm a new Arduino 101 user. Connected board via USB to a MacBook Pro. Running OS X 10.11.3 (BETA).
Launched Arduino IDE 1.6.7 and then updated libraries. I started with the very first example for using the Curie's IMU. Compiled just fine then started the upload to run the CurieIMU Orientation Visualiser example. Got the following error message at the end of the console log:
Using library CurieImu at version 1.0 in folder: /Users/RSLove/Library/Arduino15/packages/Intel/hardware/arc32/1.0.4/libraries/CurieImu
Using library Madgwick at version 1.0 in folder: /Users/RSLove/Documents/Arduino/libraries/Madgwick
Sketch uses 50,984 bytes (25%) of program storage space. Maximum is 196,608 bytes.
/bin/bash --noprofile /Users/RSLove/Library/Arduino15/packages/Intel/tools/sketchUploader/1.6.4+1.14/clupload/cluploadArduino101_osx.sh /Users/RSLove/Library/Arduino15/packages/Intel/tools/sketchUploader/1.6.4+1.14/x86/bin /var/folders/dd/s4qbh5kx7wq8yj5dtf438twr0000gn/T/build709e30c5dfe627985a50602308d68327.tmp/sketch_jan06a.ino.elf /dev/tty.usbserial-DN0091IB verbose
Starting upload script
Payload: /var/folders/dd/s4qbh5kx7wq8yj5dtf438twr0000gn/T/build709e30c5dfe627985a50602308d68327.tmp/sketch_jan06a.ino.bin
Waiting for device...
ERROR: Timed out waiting for Arduino 101.
