Everything was working flawlessly until yesterday. Today, when I try to upload I get:
Serial Port '/dev/ttyACM0' not found. Did you select the right one from the Tools > Serial Port menu?
I know that I'm connected to the board because it all works if I run the IDE as root. What's going on?
I'm running ArchLinux 64bit and Arduino 1.0.4 (error began on 1.0.3 - I updated to see if that would fix things) trying to upload to an Uno R3
Groups:lp wheel mail uucp games lock network video audio optical storage scanner power wireshark users
Permissions for /dev/ttyACM0: crw-rw---- 1 root uucp 166, 0 Mar 19 09:43 /dev/ttyACM0
StdOut:
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
check_group_uucp(): error testing lock file creation Error details:Permission deniedcheck_lock_status: No permission to create lock file.
please see: How can I use Lock Files with rxtx? in INSTALL
Binary sketch size: 1,084 bytes (of a 32,256 byte maximum)
processing.app.SerialNotFoundException: Serial port '/dev/ttyACM0' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.<init>(Serial.java:191)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:174)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:722)
I know the lock thing isn't the problem - it also happened when I was able to upload.
Thanks for the help!
