Can't use 2 servo in tinkercad, why?
i recently tried to use a PIR sensor and ultrasonic sensor that if activated at the same time move the servos as the given specs. Can you guys find what's wrong with my code?
#include <Servo.h>
Servo servo1, servo2;
#define pirPin 2
#define pinServo1 3
#define pinServo2 9
int cm;
int pirStat;
int pos1, pos2;
long readUltrasonicDistance(int triggerPin, int echoPin)
  pinMode(triggerPin, OUTPUT);  // Clear the trigger
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  // Sets the trigger pin to HIGH state for 10 microseconds
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(5);
  pinMode(echoPin, INPUT);
  // Reads the echo pin, and returns the sound wave travel time in microseconds
  return pulseIn(echoPin, HIGH);
  pinMode(pirPin, INPUT);
  servo1.attach(pinServo1);
  servo2.attach(pinServo2);
void loop(){
 pirStat = digitalRead(pirPin);
 cm = 0.01723 * readUltrasonicDistance(5, 6);
  if (pirStat == HIGH ){
    if (cm <= 10){
      pos1 = 90;
      pos2 = -90;
      servo1.write(pos1);
      servo2.write(pos2);
      delay(1);
    if(cm > 10){
      pos1 = 0;
      pos2 = 0;
      servo1.write(pos1);
      servo2.write(pos2);
      delay(1);
  if (pirStat == LOW){
      pos1 = 0;
      pos2 = 0;
      servo1.write(pos1);
      servo2.write(pos2);
      delay(1);
Quoting You: "Can't use 2 servos". Why? What stops You? Are You too young or what?
Please present facts, information, that helpers can hook on to.
Your code looks like didn't go wrong have you checked your wiring? Please tell us.
Read about the range for the angle for the Servo.write() function: https://www.arduino.cc/reference/en/libraries/servo/write/.
yes I actually had checked my wiring and it didn't had any mistake. Then I simulated it on tinkercad but my code only move 1 servo with the desired specs.
maybe this simulation will help you guys figure out what's wrong
The angle. It is about the angle. Read about the angle.
Your link to Tinkercad simulation did not work.
This link to Wokwi simulation does work : it-is-about-the-angle.ino - Wokwi Arduino and ESP32 Simulator
so basicly (-90) degree doesn't work on the Servo.write function?
I don't know if -90 works. I don't care if -90 or +1000000 works. That is not important.
The parameter for the angle can be 0 ... 180. That's all you have to know.
Do you see what I did here ? Use the library function as described in the documentation. Sometimes wrong values are ignored, sometimes wrong values are replaced by a limit and sometimes it can cause undefined behaviour. Let's not go there, follow the documenation.
When the project is powered on, and the Arduino sketch does a servo.attach(), then it defaults to its middle position. That is 90 degrees. So it defaults to 90.
@andrewtim I haven't used this software before, but you can try to change servo1.write(90); to servo1.write(180); maybe it will work. I've done something similar before, I use actual motors and try servo1.write(180); and it works.
