Hey, I want to use / or ' but it always prints # or ß or something like that...
How do I Keyboard.print this?
What keyboard locale is your PC configured for?
German
and it just prints an ß instead of an / or a ) instead of (
what's your code? what's your arduino?
if it's with the Keyboard library, try Keyboard.begin(KeyboardLayout_de_DE);
instead of just Keyboard.begin();
you might have (just guessing)
I use the Arduino leonardo and my code is just Keyboard.begin() and .print("some/text")
it's documented here
and the languages are in the source code for the library
do you have the latest packages installed?
Hi @immuc. This keyboard layout support feature was added in the latest release of the Keyboard library. Your error indicates you are using an older version of the library that does not have the feature.
The fix is to update the library by following these instructions:
Please try this:
keyboard
.Now try uploading your sketch to your Leonardo again. This time it should compile without the error and work as expected.
Still doesn't work. Here is my full code:
#include <Keyboard.h>
//#include <KeyboardLayout.h>
#include <HID-Project.h>
#include <HID-Settings.h>
// Utility function
void typeKey(int key){
Keyboard.press(key);
delay(50);
Keyboard.release(key);
// Start Keyboard and Mouse
AbsoluteMouse.begin();
Keyboard.begin();
// Start Payload
delay(3000);
Keyboard.press(KEY_LEFT_GUI);
Keyboard.press(114);
Keyboard.releaseAll();
Keyboard.print("iexplore -k http://fakeupdate.net/win10/index.html");
typeKey(KEY_ENTER);
// End Payload
// Stop Keyboard and Mouse
Keyboard.end();
AbsoluteMouse.end();
// Unused
void loop() {}
and it doesn't even work...
here is the full Error message:
In file included from c:\users\User\documents\arduino\libraries\hid-project\src\hid-apis\KeyboardAPI.h:29:0,
from c:\users\User\documents\arduino\libraries\hid-project\src\hid-apis\defaultkeyboardapi.h:27,
from C:\Users\User\Documents\Arduino\libraries\HID-Project\src/SingleReport/BootKeyboard.h:30,
from C:\Users\User\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:50,
from C:\Users\User\Desktop\ducky4arduino-master\own_scripts\rickroll\rickroll.ino:4:
c:\users\User\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:54:21: note: #pragma message: Using default ASCII layout for keyboard modules
#pragma message "Using default ASCII layout for keyboard modules"
In file included from C:\Users\User\Desktop\ducky4arduino-master\own_scripts\rickroll\rickroll.ino:1:0:
C:\Users\User\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:52:27: error: expected identifier before numeric constant
#define KEY_RETURN 0xB0
c:\users\User\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:103:5: note: in expansion of macro 'KEY_RETURN'
KEY_RETURN = 40, // Alias
C:\Users\User\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:52:27: error: expected '}' before numeric constant
C:\Users\User\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:52:27: error: expected unqualified-id before numeric constant
c:\users\User\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:521:1: error: expected declaration before '}' token
exit status 1
Fehler beim Kompilieren für das Board Arduino Leonardo.
Btw: I am trying to make a script that automatically opens the website on the PC.
Remove these lines from your sketch:
start simple
void typeKey(int key) {
delay(100);
delay(3000);
delay(100);
Keyboard.flush(); // wait for everything to be sent
typeKey(KEY_RETURN);
Keyboard.end();
void loop() {}
does this compile ?
Yes, it does. Wow it works perfectly! Thank you for your help
I'm sure all the rickrolling victims will be very grateful to you @J-M-L
I’m on a Mac, so I would never be worried about seeing Windows 10 trying to be updated by magic
Hopefully victims will learn not to connect stuff to their PC without a bit of thinking
This library can print really ALL characters of a german keyboard.
check the other library with this testcode:
#include <KeyboardGER2.h>
KeyboardGER2 myKeyBoard;
delay(2000);
delay(2000);
Serial.println( F("Setup-Start") );
Serial.println( F("For testing keep sending keystrokes in setup") );
Serial.println( F("setup is executed only ONCE") );
Serial.println( F("loop repeats execution endlessly") );
Serial.println( F("which could result in endless keystrokes") );
Serial.println( F("it is very hard to upload a new code ") );
Serial.println( F("while your microcontroller keeps sending keystrokes!") );
Serial.println( F("Set cursor-focus into a empty texteditor to make") );
Serial.println( F("the key-strokes land in this extra-text") );
Serial.println("countdown 10 to 0 then send keystrokes...");
for ( int i = 10; i > 0; i--) {
Serial.println(i);
myKeyBoard.begin();
myKeyBoard.typeText("This is a test print all characters:");
myKeyBoard.SendReturn();
myKeyBoard.typeText("ABCDEFGHIJKLMNOPQRSTUVWXYZ");
myKeyBoard.typeText("abcdefghijklmnopqrstuvwxyz");
myKeyBoard.typeText("1234567890ß?");
myKeyBoard.typeText("^°§$%&/()=");
myKeyBoard.typeText("²³{[]}\\',;.:-_<|>");
// ATTENTION ! Don't lock yourself out !
// As you are coding to send key-strokes that are just the same as
// typing on the keyboard
// whenever you put sending keystrokes in function loop
// use a button as the condition to send the keystrokes
// example
const byte myButtonPin = 5;
pinMode(myButtonPin,INPUT_PULLUP); // connect button to ground
if (digitalRead(myButtonPin == low) { // pressed button means digital low
// send key strokes
This ensures that your code is NOT flooding the IDE-Texteditor with keystrokes
right after plugging in the USB-cable
this keystroke-flooding could cause that you have a hard time to upload
new code that stops the flooding
best regards Stefan
