Hello guys for my project i want to control a stepper motor using serial commands and using a joystick. The problem is that when using both, the control command (:set:pos) doesn't work. The other commands like :get:pos or :set:speed do work. Now when i comment my joystick control (almost at the end of the code ) then my commands :set:pos does work. How is this possible?
Code:
#include <AccelStepper.h>
#include <EEPROM.h>
// Define pin connections
const int dirPinX = 2;
const int stepPinX = 3;
const int dirPinY = 4;
const int stepPinY = 5;
const int joyPinX = A0; // Analog pin for joystick X-axis
const int joyPinY = A1; // Analog pin for joystick Y-axis
// Define motor interface type
#define motorInterfaceType 1
// Creates instances for X and Y axes
AccelStepper stepperX(motorInterfaceType, stepPinX, dirPinX);
AccelStepper stepperY(motorInterfaceType, stepPinY, dirPinY);
// Variables to store target positions for X and Y axes
int targetPositionX = 0;
int targetPositionY = 0;
// Variable to store the default speed
int defaultSpeed = 1000;
// Variable to store the original default speed
int originalDefaultSpeed = defaultSpeed;
// Define joystick deadzone
const int joystickDeadzone = 500; // Adjust as needed
// Define joystick neutral zone
const int joystickNeutralZone = 100; // Adjust as needed
// Initialize Serial communication
while (!Serial) {}
// Initialize the stepper motors
stepperX.setMaxSpeed(defaultSpeed);
stepperX.setAcceleration(2000);
stepperX.setSpeed(200);
stepperY.setMaxSpeed(defaultSpeed);
stepperY.setAcceleration(2000);
stepperY.setSpeed(200);
Serial.println("\nArduino is ready to receive commands.");
// Check for serial commands
if (Serial.available() > 0) {
// Read the incoming command from Serial
String command = Serial.readStringUntil('\n');
// Convert command to lowercase
command.toLowerCase();
// Print the received command
Serial.println("Received command: " + command);
if (command.startsWith(":set:pos:x")) {
// Extract X coordinate from the command
int spaceIndex = command.indexOf(' ');
if (spaceIndex != -1) {
String xPosString = command.substring(spaceIndex + 1);
int xPos = xPosString.toInt();
// Print the target position
Serial.print("Going to position X: ");
Serial.println(xPos);
// Set the target position for the X axis
targetPositionX = xPos;
// Move the X axis to the target position
stepperX.moveTo(targetPositionX);
} else if (command.startsWith(":set:pos:y")) {
// Extract Y coordinate from the command
String yPosString = command.substring(spaceIndex + 1);
int yPos = yPosString.toInt();
Serial.print("Going to position Y: ");
Serial.println(yPos);
// Set the target position for the Y axis
targetPositionY = yPos;
// Move the Y axis to the target position
stepperY.moveTo(targetPositionY);
} else if (command.startsWith(":set:pos")) {
// Extract X and Y coordinates from the command
int commaIndex = command.indexOf(',');
if (commaIndex != -1) {
String posString = command.substring(command.indexOf(' ') + 1);
int commaIndex = posString.indexOf(',');
String xPosString = posString.substring(0, commaIndex);
String yPosString = posString.substring(commaIndex + 1);
Serial.print(xPos);
Serial.print("\tY: ");
// Set the target positions for X and Y axes
// Move the X and Y axes to the target positions
} else if (command.startsWith(":set:speed") || command.startsWith(":set:spe")) {
// Extract speed value from the command
String speedString = command.substring(spaceIndex + 1);
if (speedString.startsWith("def") || speedString.startsWith("default")) {
defaultSpeed = originalDefaultSpeed;
Serial.println("Default speed set to: " + String(defaultSpeed));
int speedValue = speedString.toInt();
// Check if the speed value is within the allowed range (100 to 2000)
if (speedValue >= 100 && speedValue <= 2000) {
defaultSpeed = speedValue;
Serial.println("Invalid speed value. Please enter a value between 100 and 2000.");
} else if (command.startsWith(":get:pos?") || command.startsWith(":get:position?")) {
// Display the current positions of the motors
Serial.print("Current position X: ");
Serial.print(stepperX.currentPosition());
Serial.print("\tCurrent position Y: ");
Serial.println(stepperY.currentPosition());
} else if (command.startsWith(":get:speed?") || command.startsWith(":get:spe?")) {
// Display the current default speed of the motors
Serial.print("Default speed: ");
Serial.println(defaultSpeed);
// Invalid command format
Serial.println("Invalid command format.");
// Read joystick input
int joyX = analogRead(joyPinX);
int joyY = analogRead(joyPinY);
// Apply deadzone to joystick input
if (abs(joyX - 512) < joystickDeadzone) {
joyX = 512;
if (abs(joyY - 512) < joystickDeadzone) {
joyY = 512;
// Check if joystick is in neutral position
if (abs(joyX - 512) < joystickNeutralZone && abs(joyY - 512) < joystickNeutralZone) {
// Stop the stepper motors
stepperX.setSpeed(0);
stepperY.setSpeed(0);
// Map joystick input to motor movement for X axis
int xPos_joy = map(joyX, 0, 1023, -5000, 5000); // Map analog input (0-1023) to motor position (0-2000)
stepperX.moveTo(xPos_joy);
// Map joystick input to motor movement for Y axis
int yPos_joy = map(joyY, 0, 1023, -5000, 5000); // Map analog input (0-1023) to motor position (0-2000)
stepperY.moveTo(yPos_joy);
// Run the motors for X and Y axes
stepperX.run();
stepperY.run();
// Save the current positions and default speed to EEPROM
//EEPROM.put(EEPROM_ADDRESS_X, stepperX.currentPosition());
//EEPROM.put(EEPROM_ADDRESS_Y, stepperY.currentPosition());
//EEPROM.put(EEPROM_ADDRESS_SPEED, defaultSpeed);
