Can't use String in digitalWrite(String,HIGH)
HI, I am newbie into programming. Trying to learn from examples and forums. This is just an example of what i want. solving this will help me a lot.
define REL1 7
String InputStr="";
void relayOn(String Relay) {
digitalWrite(Relay,LOW); //Relay is used so REL1 will be substituted. delay(3000);
pinMode(REL1,OUTPUT); Serial.begin(9600);
Serial.println("Which Relay"); delay(10000); InputStr=Serial.readString(); delay(2000); relayOn(InputStr);
Thank You
That because a String of "1" isn't the same as the (integer) number 1. (Nor is it the same as a real string of "1" or the char '1'.) Convert it to integer (Google it ;)).
Nonsense. Stop trying to use Strings AT ALL. There is no excuse for making a function that needs to operate on an integer value take a String.
void relayOn(int Relay)  {
  delay(3000);
  delay(10000);
  delay(2000);
  relayOn(atoi(InputStr.c_str()));
Robin2's serial input basics thread shows how to do non blocking serial input with null terminated character arrays (C-strings not Strings).
  delay(3000);
@boylesg:. No, according to the original code, you'd have to enter '7' to operate the relay.
boylesg: ``` void relayOn(int Relay)  {
} void loop() {
  Serial.println("Which Relay");   delay(10000);   InputStr=Serial.readString();   delay(2000);   relayOn(atoi(InputStr.c_str()));
This doesn't return the value REL1 in the relayOn function.
Please see reply #5
GrooveFlotilla:
Please see reply #5
Had to enter 7 as input. And that did. Thanks a lot people :smiley:
While learning, learn not to use String (capital S) on a system that is limited in memory. Learn to use so-called c-strings (null terminated character arrays).
