can't write to attiny167
thank you for the help in advance!
I have been learning/fighting with this ATTINY167 for the last few days. this is a clone of the digispark pro (which i will be buying a genuine board when they start shipping again but i can't wait until october to start my project) I learned a lot about fuses, what they are how they work etc and i finally got this thing working to where the PC (windows 7 64 bit sp1) will at least recognize the attiny167. avrdude can read the information on it, the pc sees it when it logs in and arduino gives the following information when i try to upload the blink sketch and it errors out without finishing the upload:
Sketch uses 912 bytes (6%) of program storage space. Maximum is 14844 bytes.
Global variables use 9 bytes of dynamic memory.
Running Digispark Uploader...
Plug in device now... (will timeout in 60 seconds)
Please plug in the device ...
Press CTRL+C to terminate the program.
Device is found!
connecting: 16% complete
connecting: 22% complete
connecting: 28% complete
connecting: 33% complete
Device has firmware version 2.0
Device signature: 0x1e9487
Available space for user applications: 14970 bytes
Suggested sleep time between sending pages: 7ms
Whole page count: 234 page size: 64
Erase function sleep duration: 1638ms
parsing: 50% complete
Erasing the memory ...
erasing: 55% complete
erasing: 60% complete
erasing: 65% complete
Starting to upload ...
Flash write error -1 has occured ...
Please unplug the device and restart the program.
the sketch code is
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(3, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(3, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(3, LOW); // turn the LED off by making the voltage LOW
OS: win 7 64 sp1
mcu: attiny167
the bootloader is ProBootloaderR2.hex
fuse settings are: -U lfuse:w:0xFF:m -U hfuse:w:0xDF:m -U efuse:w:0xFE:m
crystal is a 16mhz crystal.
fuse settings were found on digistump.com
arduino version: 1.8.5
Board: digispark pro
programmer AVRISP mkII
have tried different cables and usb ports. do not currently have another PC to try it on. any help would be greatly appreciated! I just want to be able to upload my sketches as I would like to create other projects with this MCU as it is much cheaper than things like an ATMEGA32u4.
didn't wait, ordered a 5 pack of genuine digispark pros to support the project
