hey,
I want to clone an ir signal so I can send the same signal just with the arduino,
So I'm using this code to receive ir signals:
`#include <IRLibRecvPCI.h>
IRrecvPCI myReceiver(2);
myReceiver.enableIRIn();
Serial.println("Ready to receive IR signals");
Serial.println("Point the remote controller to the IR receiver and press!");
if (myReceiver.getResults()) {
Serial.println("\n\n-------------------------");
Serial.println("Received IR signal:");
Serial.print(F("\n#define RAW_DATA_LEN "));
Serial.println(recvGlobal.recvLength, DEC);
Serial.print(F("uint16_t rawData[RAW_DATA_LEN]={\n"));
for (bufIndex_t i = 1; i < recvGlobal.recvLength; i++) {
Serial.print(recvGlobal.recvBuffer[i], DEC);
Serial.print(F(", "));
if ((i % 8) == 0) {
Serial.print(F("\n"));
Serial.println(F("1000};"));
Serial.println("-------------------------");
So I'm getting different arrays for the same button which is weird.
I got the array the repeats most:
#define RAW_DATA_LEN 24
1158, 502, 1182, 530, 334, 1346, 1158, 526,
1158, 530, 358, 1322, 334, 1346, 334, 1342,
362, 1318, 362, 1298, 1178, 502, 362, 1000};
and I used this code:
#include <IRLibSendBase.h> //We need the base code
#include <IRLib_HashRaw.h> //Only use raw sender
IRsendRaw mySender;
if (Serial.read() != -1) {
//send a code every time a character is received from the
// serial port. You could modify this sketch to send when you
// push a button connected to an digital input pin.
mySender.send(rawData,RAW_DATA_LEN,38);//Pass the buffer,length, optionally frequency
Serial.println(F("Sent signal."));
I used this code with two working Ir transmitters, one with 2 pins and the other module with 3.
Both the transmitters are working I checked with my phone.
So when I point the transmitter to the device and trigger using ENTER nothing happens I checked the led with my phone camera it's working.
What did I miss?
Thanks.
Note: I tried IRremote library it shows UNKNOWN PROTOCOL so I used this library.
