capacitive sensor
I'm trying to get my capacitive sensor to turn the brightness of an LED up and down. It is giving me the correct output 0-255 because I have debugged it.
when I set:
analogWrite(lightPin, newVal);
to:
analogWrite(lightPin, 128);
it gives it about half brightness, which is correct. So I am very confused why the variable wont translate to brightness. any ideas?
#include <CapSense.h>
CapSense cSensor(4,2);
int lightPin = 13;
int buttonPin = 3;
    pinMode(lightPin, OUTPUT);
    pinMode(buttonPin, INPUT);
    int val = digitalRead(buttonPin);
    long sensor = cSensor.capSense(30);
    long newVal = (sensor/1000)*20;
    Serial.print(newVal);
    Serial.print(", ");
    if (newVal < 255 && newVal > 20 && val == 0 ) {
      digitalWrite(lightPin, LOW);  // turn LED OFF
there is also a button too in case you're wondering, and yes it is on :slight_smile:
Try using one of the pins that supports analogWrite.
try it without the if, it can set the LED allways off (too fast to see)
    Serial.print(", ");
AWOL:
doh. that was it. totally forgot some pins don't support analog signals. thanks.
