capacitive switch variable
hi there everyone...i need your help with a capacity code.What im trying to do is a toggle switch(when i touch the foil led turn HIGH,when i touch again led turn LOW).the code i have is this one,but i don't know how to add the variable where to store the led status,so it can change every time i touch the foil.
#include <CapSense.h>
CapSense   cs_4_2 = CapSense(4,2);         // 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, add Bare Paint
int ledPin1 = 13;
   cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
    long start = millis();
    long total1 =  cs_4_2.capSense(30);
    if (total1 > 1100) {
      digitalWrite(ledPin1, HIGH);  // turn LED ON
    } else{
      digitalWrite(ledPin1, LOW);  // turn LED OFF
Serial.println(total1);
delay(100);                                          // arbitrary delay to limit data to serial port
thank you so much for help... :slight_smile:
Here's an example I wrote for toggling an LED when a sensor triggered:
const int ledPin1 = 13;
  static boolean lastSensorHit = false;
  static boolean LEDvalue = LOW;
  bool sensorHit = cs_4_2.capSense(30) > 1100;
  if (sensorHit && !lastSensorHit)  // Now true, was false
    LEDvalue = !LEDvalue; // Toggle the LED
    digitalWrite(ledPin1, LEDvalue);
  lastSensorHit = sensorHit;
  delay(100);
some variation.
int ledPin1 = 13;
int state = LOW;
int count = 1;
   pinMode(ledPin1, OUTPUT); // leds add this line
  if (total1 > 3100 && state == LOW)
    state = HIGH;
    digitalWrite(ledPin1, !digitalRead(ledPin1));   // toggle the pin only when the state goes from low to high
  if (total1 < 1500 && prevState == HIGH)   // only set the state low when the cap sense is really lower
    state = LOW;
  delay(100);
Yupii :D:D thank you so much Johnwasser and Robtillaart ...code works great,i've been with this problem for a long time,i was getting a conflict because of the library,but with your help it is solved.Thank you again guys for help :wink:
Juycce
