Capacitive Touch Piano Problem (Please Help)
I am trying to create a capacitive touch piano.
I know my wiring is correct, but the program is incorrect. I am sending it the output to Hairless MIDI Serial Bridge which is sending it to GarageBand. I know that the bridge/GarageBand is also working. The if statements are the thing going wrong. (I think) The midi notes are sequencing even when i am not touching the wires.
Code:
// Pin for the LED
int LEDPin = 13;
int noteON = 144;
// Pin to connect to your drawing
int capSensePin = 2;
// This is how high the sensor needs to read in order
//  to trigger a touch.  You'll find this number
//  by trial and error, or you could take readings at
//  the start of the program to dynamically calculate this.
int touchedCutoff = 36;
int potval;
void MIDImessage(byte command, byte data1, byte data2) {
  Serial.write(command);
  Serial.write(data1);
  Serial.write(data2);
  // Set up the LED
  pinMode(LEDPin, OUTPUT);
  digitalWrite(LEDPin, LOW);
  potval = analogRead(0);            // reads the value of the potentiometer (value between 0 and 1023)
  potval = map(potval, 0, 1023, 0, 1000);
  if (readCapacitivePin(2) > touchedCutoff) {
    MIDImessage(noteON, 60, 100);
    delay(300);
    MIDImessage(noteON, 60, 0);
  if (readCapacitivePin(3) > touchedCutoff) {
    MIDImessage(noteON, 62, 100);
    delay(300);
    MIDImessage(noteON, 62, 0);
  if (readCapacitivePin(4) > touchedCutoff) {
    MIDImessage(noteON, 64, 100);
    delay(300);
    MIDImessage(noteON, 64, 0);
  if (readCapacitivePin(5) > touchedCutoff) {
    MIDImessage(noteON, 65, 100);
    delay(300);
    MIDImessage(noteON, 65, 0);
  if (readCapacitivePin(6) > touchedCutoff) {
    MIDImessage(noteON, 67, 100);
    delay(300);
    MIDImessage(noteON, 67, 0);
  if (readCapacitivePin(7) > touchedCutoff) {
    MIDImessage(noteON, 69, 100);
    delay(300);
    MIDImessage(noteON, 69, 0);
  if (readCapacitivePin(8) > touchedCutoff) {
    MIDImessage(noteON, 71, 100);
    delay(300);
    MIDImessage(noteON, 71, 0);
  if (readCapacitivePin(9) > touchedCutoff) {
    MIDImessage(noteON, 72, 100);
    delay(300);
    MIDImessage(noteON, 72, 0);
  // Every 500 ms, print the value of the capacitive sensor
// readCapacitivePin
//  Input: Arduino pin number
//  Output: A number, from 0 to 17 expressing
//          how much capacitance is on the pin
//  When you touch the pin, or whatever you have
//  attached to it, the number will get higher
//  In order for this to work now,
// The pin should have a 1+Megaohm resistor pulling
//  it up to +5v.
uint8_t readCapacitivePin(int pinToMeasure) {
  // This is how you declare a variable which
  //  will hold the PORT, PIN, and DDR registers
  //  on an AVR
  volatile uint8_t* port;
  volatile uint8_t* ddr;
  volatile uint8_t* pin;
  // Here we translate the input pin number from
  //  Arduino pin number to the AVR PORT, PIN, DDR,
  //  and which bit of those registers we care about.
  byte bitmask;
  if ((pinToMeasure >= 0) && (pinToMeasure <= 7)) {
    port = &PORTD;
    ddr = &DDRD;
    bitmask = 1 << pinToMeasure;
    pin = &PIND;
  if ((pinToMeasure > 7) && (pinToMeasure <= 13)) {
    port = &PORTB;
    ddr = &DDRB;
    bitmask = 1 << (pinToMeasure - 8);
    pin = &PINB;
  if ((pinToMeasure > 13) && (pinToMeasure <= 19)) {
    port = &PORTC;
    ddr = &DDRC;
    bitmask = 1 << (pinToMeasure - 13);
    pin = &PINC;
  // Discharge the pin first by setting it low and output
  *port &= ~(bitmask);
  *ddr  |= bitmask;
  delay(1);
  // Make the pin an input WITHOUT the internal pull-up on
  *ddr &= ~(bitmask);
  // Now see how long the pin to get pulled up
  int cycles = 16000;
  for (int i = 0; i < cycles; i++) {
    if (*pin & bitmask) {
      cycles = i;
  // Discharge the pin again by setting it low and output
  //  It's important to leave the pins low if you want to
  //  be able to touch more than 1 sensor at a time - if
  //  the sensor is left pulled high, when you touch
  //  two sensors, your body will transfer the charge between
  //  sensors.
  *ddr  |= bitmask;
  return cycles;
Thank you soooo much!!!
Maybe you need to increase this threshold:-
Thanks! That solved my problem! (:
ServoPig:
Too easy. :slight_smile:
