I have conductive paint which works in an arduino using the capacitive touch library and when its touched i get a reading between 50 and 60 in the serial port. however i need to get the conductive paint sensor working in processing but i am having difficulty as the only output i get in processing is null and i am looking for help as to what i am doing wrong or if there is any simpler ways of going about this. I am very new to this but am desperate to get this working
code for arduino:
#include <CapacitiveSensor.h>
CapacitiveSensor cs_2_4 = CapacitiveSensor(2,4); // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add a wire and or foil if desired
long start = millis();
long total5 = cs_2_4.capacitiveSensor(30);
Serial.print(millis() - start); // check on performance in milliseconds
Serial.print("\t"); // tab character for debug windown spacing
Serial.println(total5); // print sensor output 1
// print sensor output 3
delay(10); // arbitrary delay to limit data to serial port
code for processing:
import processing.serial.*;
Serial myPort; // Create object from Serial class
String val; // Data received from the serial port
void setup() { size(400,400); myPort = new Serial(this, Serial.list()[0], 9600); }
void draw()
{ if ( myPort.available() > 0)
{ // If data is available,
val = myPort.readStringUntil('\n'); // read it and store it in val
println(val); //print it out in the console
