Hi everyone!
I'm trying to use the CapacitiveSensor library on an Arduino Nano ESP32 to measure water levels. Here is my sketch:
#include <CapacitiveSensor.h>
//using Arduino pin names (default)
#define SENDER_PIN D4 // D4 corresponds to GPIO7 ESP32 W-106
#define SENSOR_PIN D5 // D5 corresponds to GPIO8 ESP32 W-106
#define SAMPLES_NUMBER 1000
#define TIMEOUT_MS 500
#define MIN_READING 4200 // for 1M resistor and 1000 samples
#define MAX_READING 11000 // for 1M resistor and 1000 samples
byte mappedValue;
long readingRaw;
CapacitiveSensor sensor = CapacitiveSensor(SENDER_PIN, SENSOR_PIN); // 1M resistor between SENDER_PIN & SENSOR_PIN
sensor.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate
sensor.set_CS_Timeout_Millis(TIMEOUT_MS);
readingRaw = sensor.capacitiveSensorRaw(SAMPLES_NUMBER);
Serial.println(readingRaw); // for calibration
The problem is that while the sketch compiles successfully on the ESP32C3, ESP32S3, and Arduino Nano ESP32, measurements only work on the ESP32C3 and ESP32S3 Dev Modules. I've tried different resistor values from 270k to 10M, but none work on the Arduino Nano ESP32, although resistors between 270k and 1M yield results on the other two boards. I'm trying to understand what unique characteristics of the Arduino Nano ESP32 might be causing this issue.
What are the unique characteristics of the Arduino Nano ESP32 board that might prevent getting the same results as on other boards? Any help or advice would be greatly appreciated!
CapacitiveSensor.h
CapacitiveSensor.h v.04 - Capacitive Sensing Library for 'duino / Wiring
https://github.com/PaulStoffregen/CapacitiveSensor
http://www.pjrc.com/teensy/td_libs_CapacitiveSensor.html
http://playground.arduino.cc/Main/CapacitiveSensor
Copyright (c) 2008 Paul Bagder All rights reserved.
Version 05 by Paul Stoffregen - Support non-AVR board: Teensy 3.x, Arduino Due
Version 04 by Paul Stoffregen - Arduino 1.0 compatibility, issue 146 fix
vim: set ts=4:
// ensure this library description is only included once
#ifndef CapacitiveSensor_h
#define CapacitiveSensor_h
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
// Direct I/O through registers and bitmask (from OneWire library)
#if defined(__AVR__)
#define PIN_TO_BASEREG(pin) (portInputRegister(digitalPinToPort(pin)))
#define PIN_TO_BITMASK(pin) (digitalPinToBitMask(pin))
#define IO_REG_TYPE uint8_t
#define DIRECT_READ(base, mask) (((*(base)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask) ((*((base)+1)) &= ~(mask), (*((base)+2)) &= ~(mask))
#define DIRECT_MODE_OUTPUT(base, mask) ((*((base)+1)) |= (mask))
#define DIRECT_WRITE_LOW(base, mask) ((*((base)+2)) &= ~(mask))
#define DIRECT_WRITE_HIGH(base, mask) ((*((base)+2)) |= (mask))
#elif defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MK66FX1M0__) || defined(__MK64FX512__)
#define PIN_TO_BASEREG(pin) (portOutputRegister(pin))
#define PIN_TO_BITMASK(pin) (1)
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (*((base)+512))
#define DIRECT_MODE_INPUT(base, mask) (*((base)+640) = 0)
#define DIRECT_MODE_OUTPUT(base, mask) (*((base)+640) = 1)
#define DIRECT_WRITE_LOW(base, mask) (*((base)+256) = 1)
#define DIRECT_WRITE_HIGH(base, mask) (*((base)+128) = 1)
#elif defined(__MKL26Z64__)
#define IO_REG_ASM
#define DIRECT_READ(base, mask) ((*((base)+16) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask) (*((base)+20) &= ~(mask))
#define DIRECT_MODE_OUTPUT(base, mask) (*((base)+20) |= (mask))
#define DIRECT_WRITE_LOW(base, mask) ((*((base)+8)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask) ((*((base)+4)) = (mask))
#elif defined(__SAM3X8E__)
#define PIN_TO_BASEREG(pin) (&(digitalPinToPort(pin)->PIO_PER))
#define IO_REG_TYPE uint32_t
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (((*((base)+15)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask) ((*((base)+5)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask) ((*((base)+4)) = (mask))
#define DIRECT_WRITE_LOW(base, mask) ((*((base)+13)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask) ((*((base)+12)) = (mask))
#elif defined(__PIC32MX__)
#define PIN_TO_BASEREG(pin) (portModeRegister(digitalPinToPort(pin)))
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (((*(base+4)) & (mask)) ? 1 : 0) //PORTX + 0x10
#define DIRECT_MODE_INPUT(base, mask) ((*(base+2)) = (mask)) //TRISXSET + 0x08
#define DIRECT_MODE_OUTPUT(base, mask) ((*(base+1)) = (mask)) //TRISXCLR + 0x04
#define DIRECT_WRITE_LOW(base, mask) ((*(base+8+1)) = (mask)) //LATXCLR + 0x24
#define DIRECT_WRITE_HIGH(base, mask) ((*(base+8+2)) = (mask)) //LATXSET + 0x28
#elif defined(ARDUINO_ARCH_ESP8266)
#define PIN_TO_BASEREG(pin) (portOutputRegister(digitalPinToPort(pin)))
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (((*(base+6)) & (mask)) ? 1 : 0) //GPIO_IN_ADDRESS
#define DIRECT_MODE_INPUT(base, mask) ((*(base+5)) = (mask)) //GPIO_ENABLE_W1TC_ADDRESS
#define DIRECT_MODE_OUTPUT(base, mask) ((*(base+4)) = (mask)) //GPIO_ENABLE_W1TS_ADDRESS
#define DIRECT_WRITE_LOW(base, mask) ((*(base+2)) = (mask)) //GPIO_OUT_W1TC_ADDRESS
#define DIRECT_WRITE_HIGH(base, mask) ((*(base+1)) = (mask)) //GPIO_OUT_W1TS_ADDRESS
#elif defined(__SAMD21G18A__)
#define PIN_TO_BASEREG(pin) portModeRegister(digitalPinToPort(pin))
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (((*((base)+8)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask) ((*((base)+1)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask) ((*((base)+2)) = (mask))
#define DIRECT_WRITE_LOW(base, mask) ((*((base)+5)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask) ((*((base)+6)) = (mask))
#elif defined(RBL_NRF51822)
#define PIN_TO_BASEREG(pin) (0)
#define PIN_TO_BITMASK(pin) (pin)
#define IO_REG_ASM
#define DIRECT_READ(base, pin) nrf_gpio_pin_read(pin)
#define DIRECT_WRITE_LOW(base, pin) nrf_gpio_pin_clear(pin)
#define DIRECT_WRITE_HIGH(base, pin) nrf_gpio_pin_set(pin)
#define DIRECT_MODE_INPUT(base, pin) nrf_gpio_cfg_input(pin, NRF_GPIO_PIN_NOPULL)
#define DIRECT_MODE_OUTPUT(base, pin) nrf_gpio_cfg_output(pin)
#elif defined(__arc__)
#include "scss_registers.h"
#include "portable.h"
#include "avr/pgmspace.h"
#define GPIO_ID(pin) (g_APinDescription[pin].ulGPIOId)
#define GPIO_TYPE(pin) (g_APinDescription[pin].ulGPIOType)
#define GPIO_BASE(pin) (g_APinDescription[pin].ulGPIOBase)
#define DIR_OFFSET_SS 0x01
#define DIR_OFFSET_SOC 0x04
#define EXT_PORT_OFFSET_SS 0x0A
#define EXT_PORT_OFFSET_SOC 0x50
/* GPIO registers base address */
#define PIN_TO_BASEREG(pin) ((volatile uint32_t *)g_APinDescription[pin].ulGPIOBase)
#define PIN_TO_BITMASK(pin) pin
#define IO_REG_ASM
static inline __attribute__((always_inline))
IO_REG_TYPE directRead(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
IO_REG_TYPE ret;
if (SS_GPIO == GPIO_TYPE(pin)) {
ret = READ_ARC_REG(((IO_REG_TYPE)base + EXT_PORT_OFFSET_SS));
ret = MMIO_REG_VAL_FROM_BASE((IO_REG_TYPE)base, EXT_PORT_OFFSET_SOC);
return ((ret >> GPIO_ID(pin)) & 0x01);
void directModeInput(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
WRITE_ARC_REG(READ_ARC_REG((((IO_REG_TYPE)base) + DIR_OFFSET_SS)) & ~(0x01 << GPIO_ID(pin)),
((IO_REG_TYPE)(base) + DIR_OFFSET_SS));
MMIO_REG_VAL_FROM_BASE((IO_REG_TYPE)base, DIR_OFFSET_SOC) &= ~(0x01 << GPIO_ID(pin));
void directModeOutput(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
WRITE_ARC_REG(READ_ARC_REG(((IO_REG_TYPE)(base) + DIR_OFFSET_SS)) | (0x01 << GPIO_ID(pin)),
MMIO_REG_VAL_FROM_BASE((IO_REG_TYPE)base, DIR_OFFSET_SOC) |= (0x01 << GPIO_ID(pin));
void directWriteLow(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
WRITE_ARC_REG(READ_ARC_REG(base) & ~(0x01 << GPIO_ID(pin)), base);
MMIO_REG_VAL(base) &= ~(0x01 << GPIO_ID(pin));
void directWriteHigh(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
WRITE_ARC_REG(READ_ARC_REG(base) | (0x01 << GPIO_ID(pin)), base);
MMIO_REG_VAL(base) |= (0x01 << GPIO_ID(pin));
#define DIRECT_READ(base, pin) directRead(base, pin)
#define DIRECT_MODE_INPUT(base, pin) directModeInput(base, pin)
#define DIRECT_MODE_OUTPUT(base, pin) directModeOutput(base, pin)
#define DIRECT_WRITE_LOW(base, pin) directWriteLow(base, pin)
#define DIRECT_WRITE_HIGH(base, pin) directWriteHigh(base, pin)
#elif defined(ARDUINO_ARCH_ESP32)
#include <driver/rtc_io.h>
#include <soc/gpio_struct.h>
#define IO_REG_BASE_ATTR
#define IO_REG_MASK_ATTR
IO_REG_TYPE directRead(IO_REG_TYPE pin)
if ( pin < 32 )
return (GPIO.in >> pin) & 0x1;
else if ( pin < 46 )
return (GPIO.in1.val >> (pin - 32)) & 0x1;
return 0;
void directWriteLow(IO_REG_TYPE pin)
if ( pin < 32 )
GPIO.out_w1tc = ((uint32_t)1 << pin);
GPIO.out1_w1tc.val = ((uint32_t)1 << (pin - 32));
void directWriteHigh(IO_REG_TYPE pin)
if ( pin < 32 )
GPIO.out_w1ts = ((uint32_t)1 << pin);
GPIO.out1_w1ts.val = ((uint32_t)1 << (pin - 32));
void directModeInput(IO_REG_TYPE pin)
if ( digitalPinIsValid(pin) )
// Input
if ( pin < 32 )
GPIO.enable_w1tc = ((uint32_t)1 << pin);
GPIO.enable1_w1tc.val = ((uint32_t)1 << (pin - 32));
void directModeOutput(IO_REG_TYPE pin)
if ( digitalPinIsValid(pin) && pin <= 33 ) // pins above 33 can be only inputs
// Output
if ( pin < 32 )
GPIO.enable_w1ts = ((uint32_t)1 << pin);
else // already validated to pins <= 33
GPIO.enable1_w1ts.val = ((uint32_t)1 << (pin - 32));
#define DIRECT_READ(base, pin) directRead(pin)
#define DIRECT_WRITE_LOW(base, pin) directWriteLow(pin)
#define DIRECT_WRITE_HIGH(base, pin) directWriteHigh(pin)
#define DIRECT_MODE_INPUT(base, pin) directModeInput(pin)
#define DIRECT_MODE_OUTPUT(base, pin) directModeOutput(pin)
#endif
// some 3.3V chips with 5V tolerant pins need this workaround
#if defined(__MK20DX256__)
#define FIVE_VOLT_TOLERANCE_WORKAROUND
#endif
// library interface description
class CapacitiveSensor
// user-accessible "public" interface
public:
// methods
CapacitiveSensor(uint8_t sendPin, uint8_t receivePin);
long capacitiveSensorRaw(uint8_t samples);
long capacitiveSensor(uint8_t samples);
void set_CS_Timeout_Millis(unsigned long timeout_millis);
void reset_CS_AutoCal();
void set_CS_AutocaL_Millis(unsigned long autoCal_millis);
// library-accessible "private" interface
private:
// variables
int error;
unsigned long leastTotal;
unsigned int loopTimingFactor;
unsigned long CS_Timeout_Millis;
unsigned long CS_AutocaL_Millis;
unsigned long lastCal;
unsigned long total;
IO_REG_TYPE sBit; // send pin's ports and bitmask
volatile IO_REG_TYPE *sReg;
IO_REG_TYPE rBit; // receive pin's ports and bitmask
volatile IO_REG_TYPE *rReg;
// methods
int SenseOneCycle(void);
#endif
