CapacitiveSensorDue not working
Hi everyone, i'm trying to build a capacitive keyboard using the CapacitiveSensor Library. I guess CapacitiveSensorDue does NOT work since i've tried a lot of pin combination with as much resister values, but it always returns me -1 (that meas it exceed the timeout). Did anyone found the same issue and solve it?
Thanks a lot
I just used the example sketch, not more.
check the _sendBitmask and _receiveBitmask's declaring in CapacitiveSensorDue.h
if they are uint8_t try change it to uint32_t
I recently worked on this library, adding non-AVR support with optimized register writes.
https://github.com/PaulStoffregen/CapacitiveSensor
This version supports Arduino Due with optimized I/O, like the original library did only for AVR.
