I have a a small project that includes a server and a servo. The sensor's manual says that I should use a 680uF capacitor, which I have set up.
The problem is that the capacitor is needed for the sensor and if I add in a servo to the same breadboard with the capacitor, the servo struggles to move. The servo works fine if I use it without a capacitor. What are my options to get the servo working?
Share the grounds, the servo supply only to the servo so its not clobbering the supply for everything else.
Servos take 1A or more typically peak currents... Standard USB power is not sufficient for a servo, but
it looks like you are using external power. If you power the Arduino and sensor from USB, and the servo
from the external source, that ought to eliminate any issue with the servo.
