i have a project that will be run from a battery 3.7v 70mah rechargeable but i must have a min 3v going through to make the system work i have tried to find a small enough 4v+ battery rechargeable but i can't find one small enough .
so i'm thinking the 3.7v battery with a Capacitor now i've never used a Capacitor in my projects before so i need advice on how to use them as they all have different values that basically are confusing
im looking to order from here so could someone point me to the best type so i can order one please. RS online
there in only one restriction it must be no higher than 10mm and keep the diameter as small as possible. but also allowing the system to run at a min 3v min
3.7V is the "nominal" voltage for a LiPo; the charged voltage is 4.2V. At 3.7V it's only at about 1/4th of its capacity.
If your current draw is low enough there are plenty of low dropout regulators that will provide the 3V you need. Pololu.com also sells some pretty small switching regulator modules that you should take a look at.
For example an LP2985 has a dropout voltage of .28V at 150ma current draw, or .007V at 1ma draw. For a switching regulator, the Pololu D24V5F3 has a similarly low dropout.
