Capicitors 5v supply Pro Mini?
I am using a pro mini with a regulated 5v power supply, i read somewhere capacitors should be used in parallel on the power lines to the microcontroller via the VCC pin. Any recommendation on values?
thanks, mike
Such capacitors are already provided on the Pro Mini, for the Vin and Vcc, the two large parallel yellow things.
Some problems with LCD displays can be resolved by providing extra capacitors - say in the 4.7 to 22µF range - to the Vcc and ground pins of the display. Similarly for relay modules.
