#include <CapacitiveSensor.h>
* CapitiveSense Library Demo Sketch
* Paul Badger 2008
* Uses a high value resistor e.g. 10M between send pin and receive pin
* Resistor effects sensitivity, experiment with values, 50K - 50M. Larger resistor values yield larger sensor values.
* Receive pin is the sensor pin - try different amounts of foil/metal on this pin
CapacitiveSensor cs_4_2 = CapacitiveSensor(2,3); // 10M resistor between pins 4 & 8, pin 8 is sensor pin, add a wire and or foil
cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
long start = millis();
long total1 = cs_4_2.capacitiveSensor(30);
Serial.print(millis() - start); // check on performance in milliseconds
Serial.print("\t"); // tab character for debug windown spacing
Serial.println(total1); // print sensor output 1
delay(100); // arbitrary delay to limit data to serial port
It works fine with a regular Uno. How is this even possible. Aren't these pins all doing the same thing?
Darn, I'd hoped this would save me from having to wire up a switch.
Anyone ever get it to work?
