Hello, I'm new to Arduino. Can somebody please explain line by line what exactly is happening in this code?
Demo Sketch
#include <CapSense.h>/*
- CapitiveSense Library Demo Sketch
- Paul Badger 2008
- Uses a high value resistor e.g. 10 megohm between send pin and receive pin
- Resistor effects sensitivity, experiment with values, 50 kilohm - 50 megohm. Larger resistor values yield larger sensor values.
- Receive pin is the sensor pin - try different amounts of foil/metal on this pin
- Best results are obtained if sensor foil and wire is covered with an insulator such as paper or plastic sheet
*/CapSense cs_4_2 = CapSense(4,2); // 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, add wire, foil
CapSense cs_4_5 = CapSense(4,5); // 10 megohm resistor between pins 4 & 6, pin 6 is sensor pin, add wire, foil
CapSense cs_4_8 = CapSense(4,8); // 10 megohm resistor between pins 4 & 8, pin 8 is sensor pin, add wire, foilvoid setup()
{cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
Serial.begin(9600);}
long start = millis();
long total1 = cs_4_2.capSense(30);
long total2 = cs_4_5.capSense(30);
long total3 = cs_4_8.capSense(30);Serial.print(millis() - start); // check on performance in milliseconds
Serial.print("\t"); // tab character for debug windown spacingSerial.print(total1); // print sensor output 1
Serial.print("\t");
Serial.print(total2); // print sensor output 2
Serial.print("\t");
Serial.println(total3); // print sensor output 3delay(10); // arbitrary delay to limit data to serial port
This is a sample that comes with the Capsense library. Thanks.
