Capteur d'ouvrant LoRa
Bonsoir a tous,
je suis un newbie dans le LoRa et arduino,
Je voudrais quelque conseils sur mon projet
je voudrais developper quelques capteur d'ouverture et fermeture en lora et fonctionnant sur le reseau live objects d'orange pour de la notification en domotique.
J'ai trouver sur le net des tutos a base de librairie arduino-LMIC ca fonctionne bien, mais je ne sais comment le modifier pour faire du TX manuellement par bouton ou contact.
ame charitable merci d'avance
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ 0xBE, 0x09, 0x1D, 0x35, 0xF4, 0xE2, 0x00, 0xFA };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]={ 0xC5, 0x1D, 0x16, 0x95, 0x1D, 0x46, 0xE4, 0x32 };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { 0xE0, 0x5E, 0xCA, 0x7B, 0xFA, 0xB9, 0xF4, 0x2A, 0xF4, 0xE6, 0xC8, 0x2B, 0x4D, 0x96, 0x46, 0xEF };
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = "Proto1-UNO";
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 300;
// Pin mapping
const lmic_pinmap lmic_pins = {
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,
    .dio = {2, 6, 7},
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            Serial.println(F("EV_SCAN_TIMEOUT"));
        case EV_BEACON_FOUND:
            Serial.println(F("EV_BEACON_FOUND"));
        case EV_BEACON_MISSED:
            Serial.println(F("EV_BEACON_MISSED"));
        case EV_BEACON_TRACKED:
            Serial.println(F("EV_BEACON_TRACKED"));
        case EV_JOINING:
            Serial.println(F("EV_JOINING"));
        case EV_JOINED:
            Serial.println(F("EV_JOINED"));
            // Disable link check validation (automatically enabled
            // during join, but not supported by TTN at this time).
            LMIC_setLinkCheckMode(0);
        case EV_RFU1:
            Serial.println(F("EV_RFU1"));
        case EV_JOIN_FAILED:
            Serial.println(F("EV_JOIN_FAILED"));
        case EV_REJOIN_FAILED:
            Serial.println(F("EV_REJOIN_FAILED"));
        case EV_TXCOMPLETE:
            Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
            if (LMIC.txrxFlags & TXRX_ACK)
              Serial.println(F("Received ack"));
            if (LMIC.dataLen) {
              Serial.println(F("Received "));
              Serial.println(LMIC.dataLen);
              Serial.println(F(" bytes of payload"));
            // Schedule next transmission
            os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
        case EV_LOST_TSYNC:
            Serial.println(F("EV_LOST_TSYNC"));
        case EV_RESET:
            Serial.println(F("EV_RESET"));
        case EV_RXCOMPLETE:
            // data received in ping slot
            Serial.println(F("EV_RXCOMPLETE"));
        case EV_LINK_DEAD:
            Serial.println(F("EV_LINK_DEAD"));
        case EV_LINK_ALIVE:
            Serial.println(F("EV_LINK_ALIVE"));
         default:
            Serial.println(F("Unknown event"));
void do_send(osjob_t* j){
    // Check if there is not a current TX/RX job running
    if (LMIC.opmode & OP_TXRXPEND) {
        Serial.println(F("OP_TXRXPEND, not sending"));
        // Prepare upstream data transmission at the next possible time.
        LMIC_setTxData2(1, mydata, sizeof(mydata)-1, 0);
        Serial.println(F("Packet queued"));
    // Next TX is scheduled after TX_COMPLETE event.
    Serial.println(F("Starting"));
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    digitalWrite(VCC_ENABLE, HIGH);
    #endif
    // LMIC init
    os_init();
    // Reset the MAC state. Session and pending data transfers will be discarded.
    LMIC_reset();
    // Start job (sending automatically starts OTAA too)
    do_send(&sendjob);
    os_runloop_once();
code.ino (6.11 KB)
Bonsoir
Ce que tu cherches à faire dépasse le simple LoRa, il s'agit de LoRaWAN(accès à un réseau public fonctionnat en LoRa)
Si tu as un abonnement LoRaWAN Live Objects , tu as de la chance !!
très peu nombreux içi sont les heureux élus !!
un coup d'oeuil au code montre en ligne 145 un envoi d'un paquet avec les données perso (mydata[])
Ce tableau dans le code est constant et égal à "Proto1-UNO", pourquoi ne pas le rendre variable ?
Il faut bien entendu côté LIve Object une définition de l'élément reçu cohérente avec la nature de la variable envoyée
N'ayant pas été, en tant que particulier, accepté pout tester LiveObject je n'en sais pas plus.
Bonsoir,
Oui tout a fait il s'agit bien de lorawan et j'ai un abonnement a live objects,
actuellement dans les lignes de codes , il y a un intervalle régulier pour faire du TX,
Je voudrais une seulement déclencher le TX manuellement et envoyer un message fixe (ouvert ou fermer)
il me manque des connaissances sur les commandes en arduino
merci
il faudrait plonger dans la librairie LMIC pour comprendre les bonnes modifications à faire
Actuellement si je comprend bien il y un intervalle de 300s d'attente entre envois du paquet par dosend()
Cet intervalle minimal est nécessaire pour respecter le taux d'occupation de la bande 868MHz
il faudrait pouvoir ajouter une condition à cet envoi = envoyer toutes les 5' s'il ya un changement d'état d'une variable. La modification du contenu du paquet ne pose pas pb
Dans les exemples fournis avec LMIC il y a peut être de l'inspiration à prendre pour une émission ponctuelle à la demande,
Sans accès malgré, mes tentatives, à un réseau LoRaWAN Orange, Bouygues je n'y consacre pas de temps. Peut être un jour avec TheThingNetworks....
Merci de tes conseils ....
je vais me gratter la tete ...
