Capteur MMA8452Q
Hello,
I have this program but there're error but i don't know how correct these errors, help me please.
MMA8452Q Basic Example Code
Nathan Seidle
SparkFun Electronics
November 5, 2012
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
This example code shows how to read the X/Y/Z accelerations and basic functions of the MMA5842.
Ligações :
MMA8452 Arduino
3.3V ----------------------------- 3.3V
SDA -----------^^(330)^^---------- A4
SCL -----------^^(330)^^---------- A5
GND ------------------------------ GND
#include <Wire.h>
#include "MMA8452.h"
Serial.begin(57600);
Serial.println("Exemplo de uso do acelerometro MMA8452");
Wire.begin(); //Inicializa a comunicação I²C
int MMA8452(); //Testa e inicializa o MMA8452
int acelCont[3]; // Váriável que armazena os valores das leituras de 12-bit
readAccelData(acelCont); // Leitura de todos os eixos do sensor
float acelG[3]; // Variável para armazenar os valores da aceleração em g (9,8 m/s²)
// Calcula a aceleração e separa na matriz acelG
for (int i = 0 ; i < 3 ; i++)
acelG = (float) acelCont / ((1<<12)/(2*GSCALE)); // Pega o valor da e
* // Imprimi os valores na Serial*
* for (int i = 0 ; i < 3 ; i++)*
_ Serial.print(acelG*, 4); // Imprime os valores de cada eixo na serial (XYZ)
Serial.print("\t"); // Tabulação entre as leituras*
Serial.println(); //Pula Linha*
* delay(10); // Delay para ajudar na visibilidade das leitura*
}_
Which errors?
Maybe the compiler doesn't like italics - use CODE TAGS.
http://hpics.li/697e36d
http://hpics.li/eb4b2c1
Here, there're errors, i want to read information out of this accelerometer
This cannot possibly be correct.
If MMA8452 is the class which defines/controls the device, you are more likely to need something like
MMA8452 mySensor() ;
   // ... other stuff
   mySensor.init();
     float accel = mySensor.getData() ;    // or something like that -  check what function the class MMA8452 defines
You appear to be quite confused about C/C++. I suggest you download a good book and study it.
