Capteur Spo2 qui ne fonction pas
bonjour je travaille actuellement sur un programme qui mesure la saturation et qui via un firebeetle ESP-32 envoie les information sur le capteur.
j'ai téléverser le programme sur la carte mère la carte se connecte bien à internet.
malheureusement le capteur ne fonctionne pas malgré le fais que le téléversement à été effectué.
je vous met ci joint le code du programme.
[code]
  ## Hardware Connections (ESP32 Arduino):
  -VIN = 3.3V
  -GND = GND
  -SDA = 21 (or SDA)
  -SCL = 22 (or SCL)
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include "MAX30105.h" //sparkfun MAX3010X library
#include "heartRate.h"
MAX30105 particleSensor;
//#define MAX30105 //if you have Sparkfun's MAX30105 breakout board , try #define MAX30105
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "QWbvvIpO2btzVvtM-pYX1nmhMHWWN5AP"; // Token you received on your email, Replace with stars
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "DESKTOP-7OE0A3V 5786"; // Replace stars with Wifi Name/SSID
char pass[] = "797Cn<89"; //Replace stars with Wifi Password
double avered = 0; double aveir = 0;
double sumirrms = 0;
double sumredrms = 0;
int i = 0;
int Num = 100;//calculate SpO2 by this sampling interval
double ESpO2 = 95.0;//initial value of estimated SpO2
double FSpO2 = 0.7; //filter factor for estimated SpO2
double frate = 0.95; //low pass filter for IR/red LED value to eliminate AC component
#define TIMETOBOOT 3000 // wait for this time(msec) to output SpO2
#define SCALE 88.0 //adjust to display heart beat and SpO2 in the same scale
#define SAMPLING 5 //if you want to see heart beat more precisely , set SAMPLING to 1
#define FINGER_ON 30000 // if red signal is lower than this , it indicates your finger is not on the sensor
#define MINIMUM_SPO2 80.0
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
#define USEFIFO
    delay (200) ;
    while (!Serial) ;
    delay (200) ;
    Serial.println("Initializing...");
    Blynk.begin(auth, ssid, pass);
    // Initialize sensor
    while (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
      Serial.println("MAX30102 was not found. Please check wiring/power/solder jumper at MH-ET LIVE MAX30102 board. ");
      //while (1);
    //Setup to sense a nice looking saw tooth on the plotter
    byte ledBrightness = 0x7F; //Options: 0=Off to 255=50mA
    byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
    byte ledMode = 2; //Options: 1 = Red only, ET LIVE MAX30102 board
    int sampleRate = 200; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
    int pulseWidth = 411; //Options: 69, 118, 215, 411
    int adcRange = 16384; //Options: 2048, 42 = Red + IR, 3 = Red + IR + Green
    //Options: 1 = IR only, 2 = Red + IR on MH-096, 8192, 16384
    // Set up the wanted parameters
    particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
    particleSensor.enableDIETEMPRDY();
  uint32_t ir, red , green;
  double fred, fir;
  double SpO2 = 0; //raw SpO2 before low pass filtered
#ifdef USEFIFO
  particleSensor.check(); //Check the sensor, read up to 3 samples
  while (particleSensor.available()) {//do we have new data
#ifdef MAX30105
    red = particleSensor.getFIFORed(); //Sparkfun's MAX30105
    ir = particleSensor.getFIFOIR();  //Sparkfun's MAX30105
#else
    red = particleSensor.getFIFOIR(); //why getFOFOIR output Red data by MAX30102 on MH-ET LIVE breakout board
    ir = particleSensor.getFIFORed(); //why getFIFORed output IR data by MAX30102 on MH-ET LIVE breakout board
#endif
    i++;
    fred = (double)red;
    fir = (double)ir;
    avered = avered * frate + (double)red * (1.0 - frate);//average red level by low pass filter
    aveir = aveir * frate + (double)ir * (1.0 - frate); //average IR level by low pass filter
    sumredrms += (fred - avered) * (fred - avered); //square sum of alternate component of red level
    sumirrms += (fir - aveir) * (fir - aveir);//square sum of alternate component of IR level
    if ((i % SAMPLING) == 0) {//slow down graph plotting speed for arduino Serial plotter by thin out
      if ( millis() > TIMETOBOOT) {
        float ir_forGraph = (2.0 * fir - aveir) / aveir * SCALE;
        float red_forGraph = (2.0 * fred - avered) / avered * SCALE;
        //trancation for Serial plotter's autoscaling
        if ( ir_forGraph > 100.0) ir_forGraph = 100.0;
        if ( ir_forGraph < 80.0) ir_forGraph = 80.0;
        if ( red_forGraph > 100.0 ) red_forGraph = 100.0;
        if ( red_forGraph < 80.0 ) red_forGraph = 80.0;
        //        Serial.print(red); Serial.print(","); Serial.print(ir);Serial.print(".");
        if (ir < FINGER_ON) ESpO2 = MINIMUM_SPO2; //indicator for finger detached
        float temperature = particleSensor.readTemperatureF();
        Blynk.run();
        Blynk.virtualWrite(V4, ESpO2 );
        Serial.print(" Oxygen % = ");
        Serial.println(ESpO2);
    if ((i % Num) == 0) {
      double R = (sqrt(sumredrms) / avered) / (sqrt(sumirrms) / aveir);
      // Serial.println(R);
      SpO2 = -23.3 * (R - 0.4) + 100; //http://ww1.microchip.com/downloads/jp/AppNotes/00001525B_JP.pdf
      ESpO2 = FSpO2 * ESpO2 + (1.0 - FSpO2) * SpO2;//low pass filter
      //  Serial.print(SpO2);Serial.print(",");Serial.println(ESpO2);
      sumredrms = 0.0; sumirrms = 0.0; i = 0;
    particleSensor.nextSample(); //We're finished with this sample so move to next sample
    //Serial.println(SpO2);
#endif
[/code]
Bonjour
'le capteur ne fontionne pas', concrètement que se passe-t-il ?
Le capteur a-t-il été testé avec un exemple basique proposé avec la librairie de Sparkfun pour MAX30102 ?
Cette librairie pour MAX30102 est-elle compatible avec un ESP32 ?
Pas évident au vu de cet échange sur son dépot Github : https://github.com/sparkfun/SparkFun_MAX3010x_Sensor_Library/issues/31
la led du capteur ne s'allume pas. le capteur ne mesure pas.
1_ le message suivant n'apparaït pas ?
MAX30102 was not found......
2_ Quelle version du 'core ESP32' est installée ?
version core ESP32
3_ que donne un exemple basique, minimal ? Fourni avec la librairir ou dans ce style en l'adaptant si nécessaire :
http://www.esp32learning.com/code/max30102-pulse-oximetry-and-heart-rate-monitor-sensor-and-esp32.php
