Hi! I new here and could use a little help
I've put this code together from others.
The problem I'm trying to solve is having to max value continue showing and updating max
on the leds. The serial monitor works fine and stores max value.
Leds will show max value but as soon as it cools down it shows thous values.
I'm using uno, lm35, couple leds
(Not sure how to put code in box for forum)
Any help appreciated
code
//declare variables
float tempC;
int tempPin = 0; // Where 0 is an analog input
//int tempF
int cel = 0, fahr = 0; // temperature variables
int maxi = -100, mini = 100; // to start max/min temperature
int blueled = 2; //the pink led is connected to digital pin 2
int yellowled = 6; //the yellow led is connected to digital pin 6
int A = 0; // I use A to keep a value stored for the outside temperature in small numbers. At first it is zero
int C = 0; // C also helps defining what the position in the ones is. I will provide example
Serial.begin(9600); //opens serial port, sets data rate to 9600 bps
pinMode(blueled, OUTPUT);
pinMode(yellowled, OUTPUT);
tempC = analogRead(tempPin); //read the value from the sensor
tempC = (5.0 * tempC * 100.0)/1024.0; //convert the analog data to temperature
fahr = (tempC*1.8)+32; //convert celcius to farenheit
if (fahr > maxi) {maxi = fahr;} // set max temperature
Serial.println((byte)maxi); //send the data to the computer
A = fahr/10;
C = fahr-(A*10);
for (int i=0; i<(A); i ++)
digitalWrite(blueled, HIGH);
digitalWrite(blueled, LOW);
delay(300);
delay(300);
for (int n=0; n<( C ); n ++)
digitalWrite(yellowled, HIGH);
delay(600);
digitalWrite(yellowled, LOW);
delay(300);
delay(2000);
