Does the Arduino UNO have a pin with a hardware capture module? Its primary use would be pulse width decoding.
do u mean interrupt routines?
http://arduino.cc/en/Reference/AttachInterrupt
Or maybe the timer/counter's capture pins, a trigger on them will latch the current counter value.
Rob
Yes.
Graynomad:
Rob
Yes that's the idea. Interrupts would also work but using the timers makes the chore less tedious.
FWIW, I just dug out an old Input Capture sketch and posted it here:
Input Capture is described in section 15.6 of the '328p datasheet.
-br
