I want to check how often people sit on one selected bench in park. I need to gather data time: start of sitting - end of sitting.
What is the best way to catch it?
Should i use PIR sensor (how to track only sitting people, not that just are passing by?). Maybe use some piezo sensor to track vibrations that people are making while sitting and getting up from the bench. What do you recommend?
If he lives in a warm climate that will probably not work.
@ motivo is this bench at a city park or is it just a park bench on privet property.
Pressure pads are the way to go, however, I personally will not be sitting on a city bench with a pressure plate attached to it. If this is for some type of survey the results could be skewed as less people will sit on that bench. You could also find your self in some trouble.
If it is not your property you could go with a water proof ultrasonic sensor…
With a good program you could probably get reliable results with just two sensor (one per side).
That’s exactly what we used to do when I started out in traffic engineering: walk a set route taking about 10 mins to note the reg of cars in on-street parking bays. That way we measured the stay time and noted vacancy.
radman:
I think there is plenty of scope for getting into serious trouble attaching electronic devices (however innocent they may be) to public benches.
Unless of course this is a survey sanctioned or even contracted for by the council.
You didn't mention how the bench is constructed. If it has boards on it, you could loosen one and slip a pressure sensor under it. Wiring could be well hidden and a small box for the electronics out of sight underneath.
If this is a public bench then anybody seen attaching an electronic device to it will be viewed as "suspicious" even if they are wearing a council uniform.
I'm interested in designing public spaces. I want to do it, to show how many benches are poorly placed in public parks.
Here is a great movie about it: http://vimeo.com/6821934
@James C4S
I know i can count people, or pay someone but it's a lot of benches and it will take a lot of time/money to do it right :~
@Robin2
I could place pressure pad on the bench, put i think no one would sit on it. I live in Poland so in summers we have quite hot, checking temparature may be unreliable.
I want to suggest moving benches in better places, not just removing
@Grumpy_Mike
Video processing sound like it will be complicated an not scalable (many benches)
@radman
In Poland we are not so strict about placing things in public spaces
motivo:
The easy options for detecting a person sitting down all seem easy to spot and therefor unlikely to survive long on a public bench. I can't think of any hidden options which would be practical to get working and also sufficiently subtle to avoid being noticed, while also being obviously benign to anyone who does spot them.
Do you have any authority for the benches? For example, are you authorised to paint them, or repair them etc? If they aren't your benches and you have no authority to modify them then attaching any equipment to them will be problematic. Added to that, in this day and age people noticing unknown electronic equipment hidden in a public place are likely to be alarmed and once that equipment is traced to you you might find yourself facing some rather unpleasant questions. Similarly, installing hidden video surveillance equipment which records people sitting on a public bench seems like the sort of thing that people would object to in many cultures and I suppose it might even be illegal in some places.
What about a few photoresistors or a strip of photoresistors? If the bench has gaps between the wood or plastic beams, you could tuck the photoresistor between them. If some one sits down, the photoresistor value will change indicating a person is there. And photoresistors are very small, so it should fit easily between the gaps.
I wouldn't put the photoresistors where the person actually sits down, but on the part where the persons back leans against the bench, this way if someone puts a bag down, the photoresistor wont get covered and no incorrect readings.
What about a handful of capacitive sensors under the bench? They can have a range into the tens of centimeters and should work through non conductive materials (e.g. wooden bench).
I would go for the loosened plank + microswitch, hooked up to an Ardulog (www.hobbtronics.co.uk). Very small (easily hidden under the plank), very cheap, very effective, not going to be triggered by birds or squirrels.
